Driver side front window creaking when closed.
Old Mar 21, 2007 | 02:46 PM
pimpin-tl's Avatar
So I had my radio turned down and I heard the window creaking consistantly. If I lowered it about half a inch or so it almost disappeared. Any ideas on how to fix this problem? Seems to be when its closed all the way into the upper part of the seal.
Thanks.
Old Mar 21, 2007 | 03:55 PM
dan.....k's Avatar
Mine does the same thing sometimes. I really hate it.
Old Mar 21, 2007 | 04:04 PM
Will Y.'s Avatar
Registered but harmless
Try spraying 303 Aerospace into a towel and wiping the window seal (the dealer will use some silicone spray).
Otherwise, there are a couple of threads through mid-2005 in Problems & Fixes regarding quieting squeaks by inserting foam tape inside the window seals; they had photos of the process as well.
Old Mar 24, 2007 | 11:15 PM
havokgroup's Avatar
Foam tape would def fix this problem. I have used silicone spray and it works. Apply the silicone along the seal and down both run channels.
nanos
Nov 12, 2015 08:41 PM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
gqdabien
Sep 8, 2015 11:41 PM
08 NBP TL
Sep 8, 2015 08:49 PM
