Driver seat not moving correctly
Driver side seat will move all positions fine but when moving it forward it will just move the left side and points to the right. Right side doesnt move at all.
If you look under the front driver's seat, there's a motor on the left (driver) side of the car. There should be what looks like a threaded plastic piece on the motor and one on the opposite side of the seat, I think one is blue and one is white. There should be a drive shaft that connects the two, if the seat is doing as you stated, the drive shaft is either gone (should be obvious) or broken. If the shaft fell out you just need to replace it and re-thread on the caps that hold the shaft to the motor and slide, this should be pretty obvious how to do. If the shaft is missing, you'll need to replace it.
Word of advice, don't fully tighten down one side before you put the shaft in the other side, it doesn't allow enough movement if you do it this way. Once you get it seated in both sides, then tighten down the caps.
Once you get under there, what I said should be much more obvious. I bought this car yesterday and fixed the problem last night so if I can do it, so can you.
^I am not sure what part you need, but here is a link to acuraoemparts, for seat components.
Maybe #7, I am not sure what part is disconnected.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Info to anybody who has the symptoms mentioned in this post: This fixed my driver's seat. Better news: It literally takes just seconds to do this fix. I was able to reach the shaft without pulling the seat out. Both end caps of the shaft had unscrewed and were loose. Screwed them back on and now the seat works. Super easy to fix.
