Driver and Passenger Window has vertical lines
Old Mar 12, 2015 | 10:06 PM
HighTL's Avatar
Hi anyone know where these are coming from? I Heard it's from the dirt inside the door trim. I tried wiping it down with some steel wool and invisible shield which seemed to help but after a few roll downs these vertical marks came back. Should I try to clay bar them away or are they permanent? Anyone else have this issue?
My windows are not tinted (yet!).
Old Mar 13, 2015 | 07:30 PM
Hi speed's Avatar
runnin a little boost
Maybe they were tinted before you bought the car and they took it off leaving some glue. I took tint off my commute car and had glue streaks until I took the door panel off and cleaned the window and felt strip on the on the door panel.
Might be worth a try, steel wool seems extreme, so maybe your problem is something more serious.
Old Mar 16, 2015 | 09:29 AM
When people tint, they suggest 'moleskin' or felt on the inner trim to not scratch the window. It sounds like the inner trim is scratching it regardless. I'd fix it before tinting! May require removing the door panel to look at the trim itself properly and clean/replace if necessary.
Old Mar 16, 2015 | 09:58 AM
314_04TL's Avatar
Your absolutely correct. I just got my windows retinted and the guy said that in TL's you have to put moleskin in the door inserts or else its gonna scratch real bad. The tint looked terrible.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
aleo12
4G TL Problems & Fixes
Sep 17, 2015 03:48 PM
ahsm
Sep 9, 2015 08:35 AM
