Driver door problem
Driver door problem
ok i got a problem just happend today i cant open my driver door with key or remote if i press unlock on the remote the door unlocks only half way and then lock back up
if i am in side the car i cant get out
the only way i can get it is if i put my key in and twist it around a littel then the door will unlock but i gota force the key while turning it.
and another funny thing
the the door noob is unlocked i cant even close my door
only when its locked then i can close the door
I had the exact same problem with my passenger door.
When I hit the unlock button, door didn't respond, or sometimes it would, opening halfway.
Me, working at a body shop, I took the door panel off to see that the locking cord (don't know the exact name) was loose.
Basically, unscrew your door panel, and check to see if the lock cord is secured into the green piece.
It is very easy to do, no need to take it to a shop.
Just need screwdriver and be careful with pulling the other plugs out.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
