Drive belt install help
Old Jul 20, 2013 | 09:55 PM
teamsol's Avatar
Hey guys, I have been searching and have not been able to find an answer. I am installing my drive belt but I cannot get the tensioner to compress in order to slip the belt on. I attempted to turn it clockwise and counter and no luck. Any tips?!? thanks in advance!
Old Jul 21, 2013 | 06:28 AM
madpoz's Avatar
your wrench isn't long enough. there's a lot of tension on that pulley, you'll need a significant amount of leverage to move it. Go to home depot at buy a 2ft long cast iron pipe big enough to slip over the end of the ratchet. You'll be surprised how much easier it is to move with the right tools.
Turning it clockwise will undo the reverse threaded bolt holding the pulley on.
Old Jul 21, 2013 | 11:05 AM
teamsol's Avatar
I do have a breaker bar its just not on the ratchet when I took the pic. Even with the pulley off, I do not enough "belt" to wrap around the pulley. I found a few diagrams but none are specific enough to solve my issue.
Old Jul 21, 2013 | 11:12 AM
teamsol's Avatar
One more thing, I am assuming the top pulley is the tensioner which is the one I should be turning.
Old Jul 21, 2013 | 11:36 AM
pohljm's Avatar
its the same pulley you used to relieve the tension to take the belt off! you move it the exact same way
that looks like an old belt?
Old Jul 21, 2013 | 11:59 AM
teamsol's Avatar
Well its not brand new, I have a 133k it was replaced at 105k. I changed the alt and now its a pain in the ass to reinstall. Ill try again.
Old Jul 21, 2013 | 12:14 PM
teamsol's Avatar
Got it!! Holly shit youre right you really need to turn it towards the firewall. Thanks again all!
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
redsox68
Sep 16, 2015 06:18 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
asahrts
Sep 4, 2015 05:55 PM
