Drip molding replacement
Old Mar 10, 2011 | 03:44 PM
Thomasv's Avatar
The drip moldings on my car need to be replaced.
One has a dent in it that looks awful and the other has deteriorated rubber. I just called the dealership and these two thin peices cost 113 before tax...
Anyone aware of some drip moldings I can get for cheaper?
The drip moldings are basically the peices that run from the bottom of your windshield and run along the roof of the car to the top of the back window.
Old Mar 10, 2011 | 03:49 PM
Thomasv's Avatar
Old Mar 10, 2011 | 04:42 PM
Will Y.'s Avatar
Registered but harmless
I think those are $78 each from acuraoemparts.com: http://www.acuraoemparts.com/delray/...t&ListAll=Part
You might want to check the AZ vendors here too; I don't recall if a couple also sell body parts.
Old Mar 10, 2011 | 05:41 PM
VQPower37's Avatar
subscribed, could you post up a quick diy if u replace them, i might need to replace the driver's side on in the near future, i have a slight dent on mine as well
Old Mar 10, 2011 | 07:20 PM
mikedog4's Avatar
Why me??
i hate those moldings, they are a real pain in the butt to remove without bending and then wont lay flat if slightly bent.
install the new ones perfectly the first time so as to not have to remove to reposition.
Old Mar 11, 2011 | 08:08 AM
Thomasv's Avatar
Next question. I notice they sale "shoes" and "seals." I would definitely like to try to just replace the seal on one side while keeping the molding...the other one with the dent will need to be fully replaced...does anyone know if the seal they sell for this is easily replaceable?
Does anyone know what a "shoe" is?
I am guessing the shoe is some sort of clip that adheres to the molding and securely clips in to the car.
Old Mar 11, 2011 | 08:43 AM
Jesstzn's Avatar
Take a look at the bottom of this thread it shows you how to remove the strips your speaking of .. they are called weld strips.
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
Old Mar 11, 2011 | 02:52 PM
vinceeyy's Avatar
winner
thomasv, don't use other peoples pictures without asking them.
bnaritomi
Feb 17, 2016 03:22 AM
niray9
Dec 8, 2015 07:34 PM
01CLOwner
Oct 9, 2015 01:07 PM
EE4Life
Sep 11, 2015 10:13 PM
Nicho863
Sep 2, 2015 08:12 AM
