Drip molding replacement
The drip moldings on my car need to be replaced.
One has a dent in it that looks awful and the other has deteriorated rubber. I just called the dealership and these two thin peices cost 113 before tax...
Anyone aware of some drip moldings I can get for cheaper?
The drip moldings are basically the peices that run from the bottom of your windshield and run along the roof of the car to the top of the back window.
Registered but harmless
Received 1,107 Likes
I think those are $78 each from acuraoemparts.com: http://www.acuraoemparts.com/delray/...t&ListAll=Part
You might want to check the AZ vendors here too; I don't recall if a couple also sell body parts.
Next question. I notice they sale "shoes" and "seals." I would definitely like to try to just replace the seal on one side while keeping the molding...the other one with the dent will need to be fully replaced...does anyone know if the seal they sell for this is easily replaceable?
Does anyone know what a "shoe" is?
I am guessing the shoe is some sort of clip that adheres to the molding and securely clips in to the car.
Take a look at the bottom of this thread it shows you how to remove the strips your speaking of .. they are called weld strips.
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
