Door Locks with key in ignition. Locking Myself Out of Car.
So I've been locked outside of my 04 TL with it running twice in the past 2 weeks. Here's whats going on:
-Doors will lock right after shutting the door. This includes with the key in ignition running or not or key out of ignition.
-Despite adjusting settings in the MID this still happens.
-I've noticed my driver mirror also does not adjust automatically while in reverse (not sure if that is related or not).
-Items to note: Recently replaced alternator. Car was recently painted. I pulled the driver front door panel to make sure everything was connected properly.
Any ideas? I thought I've heard someone mention a door lock actuator being the culprit although I'd like to confirm.
Engineer in Training
-Are you sure you have the switch set to the left and not right or center? Also have you checked your fuses? Not just the one dedicated to what you're checking but ALL the fuses. Sometimes one circuit feeds another so the blown fuse may be in a different spot than what you would expect
-Do you have an aftermarket alarm? note: Separate keyfob is not always necessary as there are factory add-on modules
No, the car only has the factory alarm. There are no add-ons.
Not sure which switch you're referring to although all settings in MID are set so there's no auto lock function and 90 sec delay for the latter option.
Again, the doors lock about 3 or 4 seconds after shutting the door.
I haven't checked all the fuses although I'll take a look tonight and report back.
Why are you getting out of the car and leaving it running? Maybe turn the car off when you get out or don't leave the key in the ignition.
It's a failed driver's door lock actuator. the actuator is seeing a false input of a requested lock action. replace the door lock actuator and it will go back to normal. The DPMS system will not work properly when portions of this system arent operating correctly hence your mirror not adjusting down while in reverse.
nisif (12-16-2012)
Edit: NVM, his doors are locking so physical actions of actuator are good but it appears it's not sending the appropriate signals.
nisif (12-16-2012)
After ordering the actuator and preparing it for install I found the problem. It was not a faulty actuator causing the issue. There are two wiring clips that connect to the actuator, a 2 pin and a 3 pin plug. One of the wires leading into the 3 pin was overstretched due to the painter leaving the weight of the door panel on the harness. The wire was pulled slightly from the plug resulting in an intermittent connection.
I soldered an identical 3 pin plug to harness with more slack in the wire and the door locks now function as they should.
Well if anybody needs an driver front door lock actuator I have a brand new one, never installed, for a fair price. Pm or email me.
Nice to know about the MID settings, glad I ran across this topic. I was wondering why the doors weren't locking on a luxury car when my mom's Buick does and a neighbors 08 TL will.
Any fixes? Thanks!
Not sure if it's related but the memory seat settings are not working. The lights don't even come on. I'll have to Check the fuses. We replaced the passenger seat and not sure if that has anything to do with it. Or the new key fob. Or putting in the new stereo and Nav. I'm thinking after reading this thread the actuator needs replacing or the pin's are mixed as stated above.
I went in to Acura to get the Nav code for the new screen and the service/parts staffer said it sounded like a settings error or they were needing adjustments. Recently I purchased and sold a Mercedes e320 and replacing the battery the computer needed to be replaced. After replacing it the computer needed to be reset, a $67 fix through the dealership. Avoiding paying the ridiculous fee I searched on YouTube and found the steps in resetting it. Turning the key in the ignition on click, pressing down on the window button all the way and holding it down for 3 seconds and then holding it up all the way choosing it and holding for 3 seconds. Doing that to all 4 windows sync'd the one touch window feature. Same with the sun roof, holding it open then closed. Moving the seat forward then back, the head rest up and then down. And then turning the wheel 3 times to the right and 3 times to the left reset the telescopic steering wheel feature.
I was wondering in replacing the battery in the Acura if something like this was required to get the memory seat features to work and the door to lock in drive and unlock when taking the key out of the ignition.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
ahsm
09-09-2015 08:35 AM
