Door Ajar Signal
Old 01-14-2009 | 10:09 PM
NighthawkBlackPearl's Avatar
Thumbs down Door Ajar Signal
hey guys i was wondering if anyone ever had this problem..i have an 04 tl nbp 6mt and whenever it rains for a long period of time it will tell me that the rear passenger door is open, and sometimes even the front passenger door...its annoying as hell cant even arm the alarm...sometimes i even have to sleep in my car because the alarm will start going off in the middle of the night due to the "door being open" i have 81k on the car now...23k in the last 10 months 75% are probably city miles and im only 20 so i drive like an asshole...i have an aem cai and i know as soon as i go to the dealer theyll some bs about that so i dont even bother....but yea i should probably go get my car checked out before it dies on me huh
Old 01-14-2009 | 10:10 PM
also
i have no clue what im doing on these forums lol
Old 01-15-2009 | 07:50 AM
LoveMyTL-S's Avatar
Is water leaking into the door? Perhaps the eletrical contacts are getting wet.
Old 01-15-2009 | 10:32 AM
Majofo's Avatar
That's what I'm thinking. The electrical harness is connected to your door panel. If you disconnect it or short it, the latter of which the rain could be doing, it will signal that your door is ajar. Your rear window may also be in operable when it is shorted. I say check your connections and then get your seals checked if necessary.. If those aren't the culprit chase it down to the fuse box.
Old 01-15-2009 | 10:43 AM
hirsch014's Avatar
at least you admit it.
did you have it tinted? maybe they ruined the seals somewhere. check the weather stripping at the base of the windows.
Old 01-15-2009 | 05:24 PM
acuratech239's Avatar
Acura Cert MASTER TECH
Just wanted to let you guys knows that the door switch is actually located on the chassis side of the vehicle, not the door. It's just a simple 1 wire switch. When the door is closed, the switch is open. When the door is opened, the switch closes (completes the circuit to ground).
You aren't the first TL to have this problem. I get one every month or so with the complaint that they can't lock their doors, or their alarm goes off randomly. Most of the time it's a misadjusted door switch/door panel.
An easy way to test the doors is to put your windows down, close all the doors, and then grab on the door and pull out. Check to see if your interior lights come on. If they do, push back on the door towards the car and see if they go off. If that's the case, the switch probably just needs adjusted.
Occasionally they go bad, but that usually causes the door to either always read closed, or always read open, depending if it's shorted to ground, or open
(the switch, that is).
Now I will say that the rain comment does throw a slight variable into all this, which the above posts were getting into. The door switch itself is sealed inside a rubber boot, and also behind the weather stripping of the door.
I tried to keep this short and simple, hope it helps. Let me know what you find.
soupi
14
11-15-2015 11:15 AM
us285126
10-02-2015 02:03 PM
rhdune16
09-28-2015 11:31 AM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
h22lude
09-27-2015 06:22 PM
Quick Reply: Door Ajar Signal
