Dont spin tires
Old Apr 3, 2010 | 07:56 PM
8thcivic's Avatar
Dont spin tires
Hey guys - When I try to spin tiers on my 05TL-5AT it make some noise and take of relay slow when my RPM past 4 then it pulse hard but it don't spine tires like it use to what possible can be wrong.
I only hope that its not tyranny.
Old Apr 3, 2010 | 08:05 PM
stock to the bone's Avatar
because you can't spell and your grammar sucks.
try turning off VSA, i bet it would be world different.
Old Apr 3, 2010 | 08:06 PM
8thcivic's Avatar
lol smart ass i know that whene you try to do a burn out u need to turn VSA OFF
Old Apr 3, 2010 | 08:07 PM
Bearcat94's Avatar
AZ Community Team
Perhaps English is not his first language. A little tolerance might be in order.
Old Apr 3, 2010 | 08:08 PM
BoBByLiGhT83's Avatar
*WFC #162*
waiting for the grammar police to chime in
Old Apr 3, 2010 | 08:09 PM
8thcivic's Avatar
english is my forth language by the way
Old Apr 3, 2010 | 09:39 PM
jisleyjr's Avatar
Are you trying to power brake?
Old Apr 3, 2010 | 10:36 PM
csmeance's Avatar
more than likely it's your VSA kicking in, if you are powerbraking there might be a chance that's it's the ABS system.
Old Apr 3, 2010 | 10:39 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Well, your title says it. Don't spin your tires.
Old Apr 4, 2010 | 03:24 PM
8thcivic's Avatar
Ill make a video today so you guys can see what i`m talking about
Old Apr 4, 2010 | 03:49 PM
d-townhakuzo's Avatar
Haha, well put. Honestly, it sounds just like what happens if I try to spin the tires with VSA on. I think it is VSA related.
Old Apr 4, 2010 | 07:02 PM
shadowkahn's Avatar
you say it doesn't spin them like it did before. How many times have you done this before? Could it be that you've been tearing up your car doing this stuff for a long time?
Old Apr 4, 2010 | 08:52 PM
8thcivic's Avatar
this what im talking about it pulls slow http://www.youtube.com/watch?v=xygkq2Uz1YQ
Old Apr 4, 2010 | 10:39 PM
That video helped not a single bit...
Old Apr 4, 2010 | 10:45 PM
8thcivic's Avatar
^ then u slow because my boy spin tires on his TL whene he take of and he got 20`s on it
Old Apr 4, 2010 | 10:46 PM
did you completely floor the gas? were you braking while flooring the gas? And i didnt see or hear the pulse that you were talking about.
i could only come up with 3 guesses
1. your engine lost its power
2. your tranny is ruined
3. your tires are hella sticky.( which i doubt)
Old Apr 4, 2010 | 10:47 PM
8thcivic's Avatar
I just purchase the car like 4 months ago and only drove for 5k on it
Old Apr 4, 2010 | 10:51 PM
how many times have you tried to do burn out?
8thcivic's Avatar
stock to the bone yes I completely floor the gas and the pulse u only can here in the car for some reason.
Old Apr 4, 2010 | 10:53 PM
8thcivic's Avatar
2 times
Old Apr 4, 2010 | 11:03 PM
8thcivic's Avatar
and this is how it use to be http://www.youtube.com/watch?v=HLFIj...eature=channel
Old Apr 4, 2010 | 11:19 PM
Yonkers914's Avatar
04Tl
that doesnt help either cause the road was wet and cold but ok.
Old Apr 4, 2010 | 11:42 PM
Will Y.'s Avatar
Registered but harmless
It sounds like your boy has sucky POS tires on his wheels.
What brand/model/size tires are on your TL?
Old Apr 5, 2010 | 08:31 AM
niro6's Avatar
7th Gear
i think i know what your talkin bout. i'm experiencing same issues wit my 07 type-S 6MT. i'm gonna take it into the dealer today. this problem started for me after they changed my 3rd gear synchros due to the 3rd gear lock out problem.
Old Apr 5, 2010 | 08:37 AM
blkaspec's Avatar
Full of water...
But the real question we should all be asking is, why in the heck are you trying to spin your tires? I like my car, and tires, too much to put it through that kind of abuse.
Old Apr 5, 2010 | 10:27 AM
ChicagoNick's Avatar
ChicagoNick
To Answer your question...
IF these are really the only 2 times you admit to spinning your tires (which I don't believe) then...
First video: you are on dry pavement... looks warmer out based on your choice of jacket. Tires stick better in this environment. Hence, less tire spinning action.
Second Video: ground is wet plus cold. Anyone can spin tires when the ground/tires are wet. Also, when it's freezing out, tires lose traction easier, there is generally a loss of tire pressure in cold temps(i'm assuming you don't regularly check tire pressure), and salty asphalt is slicker than clean asphalt. Result: massive tire spin.
I hope this answers your questions thoroughly. Two completely different road/weather conditions cannot be compared to eachother.
now, my
I am guessing that, in reality, you try to spin your tires every single time you drive it. Otherwise you wouldn't so concerned about it. Spinning the wheels on a front-wheel drive car is no big feat(Also, videotaping it is :ghey. After 5000 miles of abuse... your transmission and engine have probably started to feel it. Good luck with all that.
Old Apr 5, 2010 | 10:53 AM
1fsthatch's Avatar
this thread FAILS
Old Apr 5, 2010 | 10:55 AM
1fsthatch's Avatar
You have summer tires on the 6MT very very sticky, finally getting soem good weather up there 2 huh
Old Apr 5, 2010 | 11:08 AM
alexSU's Avatar
Under construction
i bet the OP will understand after he has to replace the tires a few times...or the transmission
Old Apr 5, 2010 | 11:12 AM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
This thread is hilarious.
Old Apr 5, 2010 | 11:20 AM
SOCAL BRO!!!'s Avatar
got brohoes?
Bro, pull the e-brake and take VSA off then try. That second video had the e-brake on.
Old Apr 5, 2010 | 03:12 PM
csmeance's Avatar
Consider this your warning, AcuraZine does not tolerate any sort of insults towards any other members, especially calling them slow when they are trying to help you. Next offense and you'll get a vacation.
Old Apr 5, 2010 | 04:51 PM
choiyn98's Avatar
+1
I would not do that to my car...
Old Apr 5, 2010 | 11:51 PM
AMUA6's Avatar
ScoobyZINE
Just slowly approach a wall with your front bumper, with the front of your car rested against the wall, floor it! Or even put bleach all over and under your front tires if you want some kick-ass video action!
Old Apr 6, 2010 | 12:47 AM
eg5's Avatar
eg5
user title goes here
funny thread
Old Apr 6, 2010 | 02:24 AM
gotkilled's Avatar
NBP is a pain...
why would you want to spin your tires out? I don't get it...
Isn't the point to get good grip and traction on your tires so your tires don't spin out when you accelerate?? LOL!
Old Apr 6, 2010 | 02:35 AM
Sal's Type S's Avatar
Turn OFF Traction control (VSA)
Old Apr 6, 2010 | 11:27 AM
8thcivic's Avatar
^ VSA is off check the video
Old Apr 6, 2010 | 11:32 AM
WRXtranceformed's Avatar
#ForcedInductionFamily
I blame the tyranny.
Old Apr 7, 2010 | 12:19 PM
8thcivic's Avatar
I found out that is my first gear so now me and my boys rebuilding it by next week Ill be done
