Doesn't start immediately
I just bought a 2005 TL, it has 95k miles so I will do the 105k service soon.
The only issue I have noticed thus far is the car "struggles" to start, I have to hold the key a little longer than normal and the car kinda chokes and than starts.
Just wanted to see if this was an additional problem I should have looked at or it could be something related to scheduled maintenance, spark plugs maybe?
Hopefully it is not a big issue, now that I am thinking of it, I test drove 2 TLs and both of them I failed to start on the first try. So I figured it could be a common problem
the overexplainer
I kind have noticed this too with my TL, seems to happen when it's starting when cold. When I crank it for 1-2 seconds it sort of stumbles when it catches and starts. After warming up it's more or less OK if i need to restart.
It's at the point where i noticed it..since my mother's 01 odyssey starts right up I'm thinking why cant my TL do the same..essentially the same engine.
havent had it fail to start though so I guess it's ok...
the overexplainer
The car sometimes does this to help reduce emmisions on startup. However if it's a continual problem, turn on the car to position 2 (the fuel gauge reads a level) and then turn on the car. The fuel pump primes itself when you do this. If it starts up perfectly after doing that you should consider adding a fuel cleaner to clean up some of the crud in the tank and fuel lines and injectors.
Guess i'll live with it. It's not a problem, just something quirky I guess. I definitely dont have issues starting the car at least or have to crank for a few seconds.
yea pausing to prime the pump first doesnt make a difference. That was a habit i brought over from my old integra.
