Does your TL vibrate like this?
Old Feb 20, 2012 | 07:13 PM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
Im kind of paranoid right now because it seems lately I can feel vibrations through the seats while the car is in the Park position. I do have a cracked side motor mount. Would that be the cause? or is it more to that?
Here's a video:
http://s4.photobucket.com/albums/y10...-45-57_126.mp4
Not sure if that's suppose to be normal. Any help would be appreciated!
Old Feb 20, 2012 | 07:16 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
does it change when you rev the engine?
Old Feb 20, 2012 | 07:19 PM
TWiSDiT's Avatar
Hey Jamie, what do you mean does it change when I rev? as in does it get worse?
Old Feb 20, 2012 | 07:25 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
does it get worse or stay the same? i would think its a motor mount issue if you are getting bad vibrations at idle (or your engine is all goofed with the valves and timing). isn't there some method to determine which mount it is? soemthing about watching the engine and putting the car in drive or reverse (of course with the front of the car raised). i remember reading something about that on here.
Old Feb 20, 2012 | 07:29 PM
TWiSDiT's Avatar
I didnt try revving but ill try tomorrow and keep you posted. I know for a fact the side motor mount is cracked because you can see it. Not sure about the front and rear mounts. My car does make a pretty loud clunk with throwing into reverse but it seems its off and on, some days it does it, some days it doesnt..
Old Feb 20, 2012 | 07:33 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
get your mounts replaced...excessive vibrations would drive me nuts. of course right now my TL is queened and only driven once a week (i mean really, does the county and VDOT have to cake the road in road salt and brine spray for the total lack of snow we got-which was NONE!).
Old Feb 20, 2012 | 07:34 PM
mY sLOW UA6's Avatar
That motor mount is probably your problem.
Old Feb 20, 2012 | 07:42 PM
TWiSDiT's Avatar
yeah, i figured it might be the mounts. You can only feel it when the car is in Park and idling. During normal operation, its fine.
yeah, ima try check up on the prices and DIY, hopefully i can do this weekend or something
Old Feb 20, 2012 | 10:20 PM
diesel_s's Avatar
I've got to find a DIY too, onto of my mounts is out and I get the same clunk every now and then when going into reverse
Old Feb 20, 2012 | 10:35 PM
swoosh's Avatar
takin care of Business in
this is how i would go about diagnosing your problem:
1> Vibrations when braking at high speeds: Warped rotors
2> Vibrations when driving between certain speeds: Balance issues, Bent rim, bubble in tire, axle, hub-centric rings
3> Vibrations when at a stop: Vac line, mounts
Old Feb 22, 2012 | 11:37 AM
kingkong_dav's Avatar
KingKong_Dav
damn moounts it is
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
