Does anyone have this problem
Old Oct 15, 2008 | 08:59 PM
TLIN4LIFE04's Avatar
09 tl-sh
Cool Does anyone have this problem
When i first turn on my 04 tl it trembles for about a minute is this normal. Im a newbie tlin4life
Old Oct 15, 2008 | 09:04 PM
ttribe's Avatar
I don't. But I live in a pretty warm climate. Nevertheless, if it is excessive (which it sounds like it may be), then that doesn't sound right. Perhaps a visit to a dealership is in order.
Old Oct 15, 2008 | 09:07 PM
09 tl-sh
Cool
Kool
Old Oct 15, 2008 | 10:05 PM
BukvaMan's Avatar
Mine used too fro some reason now it doesnt anymore or at least not as much althoe i did change the crank pulley for an aluminum one. and i upgraded my battery ...
Old Oct 16, 2008 | 12:06 AM
vi3tboi's Avatar
2013 MDX
i dont know if thats normal but i actually get the same thing but im in canada and it gets really really cold here soo i figure its just cold and it goes away after the car gets warmer
Old Oct 16, 2008 | 05:41 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
It's normal to get a tremble. If you listen to your exhaust as the car warms up its louder then you hear it die out and the reason ive learned for all of this is because of the ULEV system. Plus when the car 1st starts the Rpm's are generally 1,300 or so. On your average car they can be up at 2K+ so all of these things factor in, and its mainly due to the Ulev system.
To clear up the exhaust noise, I have a comptech exhaust and during start up its pretty deep in tone and if you listen closely it sounds like a switch valve was turned on you can hear the tone get very quiet. Yet the car isn't warmed up yet and the temp is still @ (c)
Old Oct 16, 2008 | 07:14 AM
wuiwui85's Avatar
Boosted...
I live in South Dakota, I have the same problem and its during the summer has well, yesterday it was about 30F I was thinking of changing out my spark plugs this wouldn"t help would it???My car has 36K 2005
Old Oct 16, 2008 | 03:08 PM
csmeance's Avatar
like the others have said, its the ULEV II system. What it does is it revs the car at 1000-1300 RPM's. This helps the car warm up faster to operating temps so less gas is wasted during driving. IT is normal, it you feel it is excessive, check your motor mounts, if they are not broken, neutralize them by making them finger-tight, shifting between park, drive, neutral, reverse, drive and neutral. Then while in neutral tighten mounts.
Old Oct 17, 2008 | 03:17 PM
RACINGHART03's Avatar
Actually the tremble is emission related but its not RPM related. The reason being that a severely rich misfire will destroy catalyst material as you might know. A "controlled" misfire will heat a catalyst quickly thus increasing the efficiency of the catalytic converter. What you feel is the car slightly misfiring to get the cats up to operating temperature as quickly as possible to reduce overall tailpipe emissions. There..now you know.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
