DIY A-105: Power Steering Pump Overhaul (with Pics & SM Scans)
Old 01-18-2012, 09:27 PM
  #41
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
i will be changing the pump seal, the one that the OP missed, while im at it just to be 100% to stock the leak. i will also take pictures to add to this thread for that last seal.
rockstar143 (07-18-2012)
Old 01-19-2012, 03:14 AM
  #42
21 Acura RDX Aspec
JayVee's Avatar
Well... It has been confirmed. This morning was the ULTIMATE test to confirm if the o-ring was my problem. In the mornings the whinning noise while at idle is loud and even louder when steering, until all warms up and disappears (just as the vid posted by BEARCAT posted). This morning was only the sound of a running motor...YAY! 100% confirmed FIXED! and was the solution to my problem. But not saying it will be someone elses fix.
Pls resort to this thread in general for repairs on the PS pump issues 3G TL owners experience.
Old 01-19-2012, 05:23 AM
  #43
do you guys think my leak is similar?
Old 01-19-2012, 05:53 AM
  #44
21 Acura RDX Aspec
JayVee's Avatar
Mine was JUST LIKE the vid... Yours is just as ROCKSTAR143 has explained his was... I would say yes! Rebuild/gasket/seal your pump as his write up shows. What do have to lose?
Old 01-19-2012, 08:07 AM
  #45
rockstar143's Avatar
Received 19,982 Likes on 14,493 Posts
Yours is IDENTICAL to mine...down to the color and consistency of the fluid. I knew it wasn't oil...it feels a little like honey. Although not as delicious...
It worked for me...rebuild with the new orings I mentioned above and you should be golden. Mine is bone dry now.
Old 01-19-2012, 08:40 AM
  #46
21 Acura RDX Aspec
JayVee's Avatar
Damn it RS143! I told u to keep your tongue off car parts! Especially once with fluids.
Old 01-19-2012, 07:47 PM
  #47
Dude...HONEY...can you NOT lick honey?!?!
Old 01-19-2012, 08:19 PM
  #48
the overexplainer
ez12a's Avatar
everyone's so gdamn excited in this thread lol.
i should check if my p/s pump is leaking. My pre purchase inspection noted a "oil pan gasket leak"..i wonder if it's coming down from the p/s pump instead.
Old 01-19-2012, 08:27 PM
  #49
When troubleshooting my issue, I thought it was the oil pan gasket too...but if you look at the fluid, it probably won't be oil. If not, this is your problem.
I think it's a new issue...for 04's or so. I bet more and more people will start figuring out their ps pump is leaking...it's got to be a problem for similar year/mileage and climate (hot...makes the o rings crispy quick).
J>
Old 01-20-2012, 03:13 AM
  #50
21 Acura RDX Aspec
JayVee's Avatar
Definitely worth checking. Hey, there is nothing wrong with a lil excitement. YAY! lol!
Old 01-20-2012, 06:48 AM
  #51
I think he meant positivity...and I know most of my threads are oozing with it.
Old 01-20-2012, 06:51 AM
  #52
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
My car has that leak from ever since, I should get off my ass and do it
Old 01-20-2012, 07:14 AM
  #53
21 Acura RDX Aspec
JayVee's Avatar
DOOooEEEeeettt U BUM!
Old 01-20-2012, 09:25 AM
  #54
Well, I'm honestly glad this thread might be helping some people out. I had a feeling if my car...that has been well cared for and properly maintained had this problem at 76K, it was probably more prevalent than we all thought. Plus, it's not mission critical since it won't throw out a CEL or even affect performance (assuming you don't let your reservoir get dry). BUT, I didn't feel very good knowing there was a fluid leaking down the side of my engine.
J.
Old 01-20-2012, 10:05 AM
  #55
21 Acura RDX Aspec
JayVee's Avatar
J.
ABSOLUTELY helped me and I know others...Like u said, if u experiencing the problem, someone else has to be also. Even if mine wasn't the exacr same, it was still a issue addressed that others have had also. WIN ~ WIN for ALL! Great Job!
rockstar143 (01-23-2012)
Old 01-23-2012, 01:14 AM
  #56
I did my power steering seals this weekend....but ended up not doing the one behind te pulley because i didnt have a way to remove that bolt. Okay so everything looks good, but now I have that infamous power steering pump whine. It sounds exactly like the one in the power steering pump whine thread, but my seals are all new... What do you guys think?
Old 01-23-2012, 02:56 AM
  #57
21 Acura RDX Aspec
JayVee's Avatar
is it burping or leaking our of the rezzie out after driving or ideling? (like the vid shows?)
Old 01-23-2012, 08:54 AM
  #58
Did you put some fluid on all the new seals? I also did not do the one behind the pulley.
Did you tighten down all the 10MM bolts really well?
Old 01-23-2012, 08:09 PM
  #59
Yes, I even bought a new seal for the inlet hose(again), but it still did not solve the steering pump whine. It's exactly like the video shows, there is fluid bubbling up when turning and the noise is exactly same.... Perhaps one of my seals inside the pump wasn't seated correctly? Any ideas?
Old 01-23-2012, 08:33 PM
  #60
Has to be, brother. You SURE you removed all the old seals? some of them are stubborn and needed to be picked out.
Also, I notice in the image of parts, there are a lot of hoses etc...how about the inlet/outlet on the reservoir, or all the connections to the hoses.
You're CERTAIN it's PS? I thought it was my ps pump originally and ended up being bad bearing on my tensioner pulley.
Old 01-24-2012, 06:09 AM
  #61
21 Acura RDX Aspec
JayVee's Avatar
Yes, its def drawing in air from somewhere...Good Luck finding it bro! I know its a pain!!!
Old 01-24-2012, 06:33 AM
  #62
The main problem with troubleshooting THESE noises is you only have the issue with the car on and with the engine on you can't hear where the fk it's coming from!
Old 01-24-2012, 06:54 AM
  #63
i had a friend help me turn the steering wheel so i confirmed its coming from the pump...i will take apart the pump again to check the seals later today.
Old 01-24-2012, 01:03 PM
  #64
Wow...what a PITA!!!
Did you make sure the seal stayed seated properly when you bolted down the 4 bolt cover?
What I did was put the shaft with all the appropriate seals upside down on the ground and then put the power steering pump down onto it, then bolted...otherwise the seal could move off center.
Hope it's an easy fix, man.
Old 01-25-2012, 12:34 PM
  #65
I opened my pump again and re-seated everything and now there's no more sounds
Old 01-26-2012, 09:06 PM
  #66
Fkn AWESOME!
Was I right about the rings not seating properly and then getting bolted down? It's tough to line it all up unless you flip the assembly upside down.
J.
Old 01-28-2012, 02:50 PM
  #67
well everything look fine to me but i just re-seated all the rings and tightened all the bolts and made sure to double check all my work. in any case my power steering pump is all good now. today i opened my hood and i saw my clean power steering pump without any residue of leaking fluid....and i was like, acurazine saved my power steering pump
Old 01-28-2012, 06:51 PM
  #68
glad to hear it...ain't that the truth. AZ to the rescue again.
Old 02-18-2012, 01:26 PM
  #69
jb879123's Avatar
my power steering whines a bit, mostly when turning if the car is at a low speed or at idle. the noise goes away with speed. i replaced the inlet o-ring recently, which was already the orange one. the whine persists. i bought the car used in may. it now has 102k on it. would everyone say the o-rings are worn and this could be a good solution?
Old 02-19-2012, 09:12 PM
  #70
SpiderX1016's Avatar
Great, now mine is leaking. It wasn't leaking when I did an oil change 5k miles ago.
I'll get some pictures on the one behind the pulley. You'll need an impact wrench to remove the pulley, some snap ring pliers and a socket to hit the seal in place.
I'm gonna be doing another reseal this weekend.
Old 02-20-2012, 09:27 AM
  #71
Yeah, let me know how that goes please...that was the ONE o-ring I didn't change although mine is NOT leaking anymore after changing ALL the other seals.
J.
Old 02-20-2012, 10:31 PM
  #72
diesel_s's Avatar
thank you!!! i am saving this! I wonder if this will solve the issue I've been having or hard steering at low speeds
Old 02-21-2012, 06:59 AM
  #73
I would hope so...maybe it's not flowing properly...the accessory belt ok?!?! that's odd...
Old 02-23-2012, 06:43 AM
  #74
jb879123's Avatar
exactly same here. Whining and hard steering at low speeds. No leak from pump. No air bubbles. Possibly a leak somewhere else? Like in the rack?
I'm at 102k, on possibly the original drive belt. I was supposed to do the 105k service this week but haven't had time. Could the belt be stretched on and out of spec, affecting the performance of the power steering pump? The AC seems to start hard too, and that runs off of that as well?
My family owns a tree company, and a couple weeks ago the performance of the hydraulics on a stump grinder had gradually gotten bad. Finally the belt that drives the pump snapped. So possibly similar to my car?
Old 02-23-2012, 07:58 AM
  #75
#1 Super Guy!
94eg!'s Avatar
Because these cars use a spring-loaded auto tensioner, the belt either works or it breaks. It's not like the old days where the belt will start to slip if it stretches too much. It's kinda a bad thing because there is very little warning that the belt is going to fail.
There is a chance that the spring-loaded tensioner itself is failing and not applying enough tension to the belt. But I would think that you would get a bunch squealing noise as the belt would start to slip. I'm not 100% on this though.
Old 02-23-2012, 08:58 AM
  #76
Plus, the bearings on my pulleys on the tensioner assembly took a dump way before I had a problem with tension. This is very strange...almost seems like a lack of flowing of the fluid, rather than a leak.
Old 02-23-2012, 04:14 PM
  #77
jb879123's Avatar
there is significant squealing from the pulleys when the car is on. Months ago I sucked some fluid out of the reservoir and exchanged for new. The whining wad fixed for a while but came back. I suppose if I complete the 105k service and flush PS fluid the whine and hard steering should be gone. If not, I've got bigger problems, right?
this thread is pretty awesome btw
Old 02-23-2012, 06:33 PM
  #78
^^^I wish I knew...the bearing thing coupled with the possibility that the belt is slipping...might be part of it. The belt tensioner swap and belt swap is a 30 minute job.
Thanks btw...
Old 02-23-2012, 06:49 PM
  #79
jb879123's Avatar
well hopefully I will have time to do the whole 105k service next Saturday. When I do I will report back.
Old 02-23-2012, 08:53 PM
  #80
Are you tackling yourself!?!?
If so, you'll be schooling my ass up and down this forum. I keep rereading the DIY thread on it...it ain't happening!
Quick Reply: DIY A-105: Power Steering Pump Overhaul (with Pics & SM Scans)
