Discolored Mirror!
Old Feb 14, 2011 | 02:42 PM
BAM1369's Avatar
Discolored Mirror!
My driver side mirror is discolored. I dont know why, i guess maybe weather + heated mirror?
There is no way to clean it off because its behind the glass.
So where can i get a new mirror or how can i fix this? Anyone else have this problem?
I want to get this fxed asap, i cant stand looking at it any more.
Old Feb 14, 2011 | 02:44 PM
the mirror heater was set on for too long.
Old Feb 14, 2011 | 05:18 PM
cjTL's Avatar
I'm Craig
Yeah the mirror heat button was left pushed in for a long time. Common issue with 3G TLs.
Old Feb 14, 2011 | 05:29 PM
nfnsquared's Avatar
If you have an extended warranty, you should be covered. If not, talk to your service manager. Some dealers have fixed this on goodwill...
Old Feb 14, 2011 | 10:40 PM
bacardi_sip's Avatar
I replaced mine recently under warranty. I had to talk to acura warranty dept and explain to them the color faded due to faulty electrical equipment and only after that they agreed to cover it under warranty.
Old Feb 15, 2011 | 07:13 AM
BAM1369's Avatar
Ok ill check with the dealer. This only happened to the driver side not the passanger side so that makes me think in a defect not a problem with leaving it on too long. The mirror should be able to hold up to the heat probuced by it own heating system.
Old Feb 15, 2011 | 07:26 AM
BAM1369's Avatar
Anyone know how to take just the glass out of the side mirror? Should I just pull on it like on my old accord?
Old Feb 15, 2011 | 07:24 PM
guitarplayer16's Avatar
It's easy, and if you buy the glass at the dealer, have them install it for you.
Old Feb 15, 2011 | 09:21 PM
GTkim83's Avatar
HER!? yeah..i kno ;)
This happened to my mirrors too and the dealership on rt.18 refused to fix it under warranty...and yes i do have an extended warranty and my car is 05 TL 79000 miles..
Old Feb 15, 2011 | 10:01 PM
nfnsquared's Avatar
No, it's a known defect. Plenty of threads on this issue.
Do a search, there are plenty of folks who got it replaced under the OEM warranty. If you're extended warranty is through Acura, I'd think it would apply to this. Take a print out of all the posts on Azine about this problem with you when you go back to the dealer.
Old Feb 19, 2011 | 07:54 PM
eduble2's Avatar
I also had this problem with my 05 Acura tl on the passengers side mirror. The dealer stated that the reflective part of the mirror faded and that I need to replace it. I spent 1500 that day and they didn't fix it under "good will".
Old Mar 1, 2011 | 04:15 PM
clapham's Avatar
My dealership told me it wasnt covered under extended war. Sucks, guess I will live with it.
Old Mar 1, 2011 | 06:52 PM
jungy4's Avatar
I have the same issue. The service manager told me it is not covered under certified used warranty. Should I call Acura customer service to try to get this replaced?
Old Mar 2, 2011 | 10:02 AM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
I ordered my passenger side one and it's sitting at home waiting to be popped on ($38). These pop on and off, just use a screwdriver and pop it off. make sure you put a rag between the screwdriver and mirror housing so you don't scratch your paint.
Old Mar 2, 2011 | 11:45 AM
sddale's Avatar
My drivers side mirror just started doing this a few weeks ago. The strange thing is that there were no signs of this until it came to a cold weather area. I have used the mirror heater twice for less than 3 min each time. I have a heated garage that never gets below 45 but it does get to -10 outside. I wonder if coming from subzero temps outside to 45 in the garage repeatedly caused it. Either way it's annoying as hell.
Old Aug 23, 2011 | 11:18 PM
Magikmanzx's Avatar
Ive never used my heated mirrors and this happened to me on the driver side
Old Sep 1, 2011 | 05:16 PM
TLin05's Avatar
05NHB - just sent you a message on this .... wondering how it worked out for you. I have same issue both sides. I'd also venture an opinion FWIW that the heated mirror function has nothing to do with it.
Old Sep 1, 2011 | 05:34 PM
swoosh's Avatar
takin care of Business in
i put 35% tint on the mirror and it solved the issue (if i dont see the discoloration, its solved LOL )
Old Sep 2, 2011 | 11:44 AM
n4h's Avatar
n4h
Nice lol, how's the visibility with the tint on? Did you cut it yourself?
Old Sep 2, 2011 | 12:43 PM
swoosh's Avatar
^^^ visibility is very low considering I have 16% tints on my windows....i have to roll my windows down when I have to reverse back to see anything LOL....
yes i did cut then myself with a exacto knife...
Old Sep 2, 2011 | 02:52 PM
mikedog4's Avatar
Why me??
replaced both mine last month, took about 10 mins total. very easy
Old Sep 2, 2011 | 02:58 PM
paperboy42190's Avatar
the mirror is only $35, and 10 min to fix.
Old Sep 3, 2011 | 12:58 PM
UMBERT's Avatar
https://acurazine.com/forums/3g-tl-problems-fixes-114/replacing-glass-bleeding-sideview-mirrors-728192/
https://acurazine.com/forums/3g-tl-problems-fixes-114/outside-mirrors-failing-723012/
post #s: 8, 10, 11
DIY - https://acurazine.com/forums/3g-tl-2004-2008-93/repairing-side-view-mirror-3g-garage-e-045-a-573130/
parts needed - http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Nov 3, 2017 | 12:41 PM
nfnsquared's Avatar
Anyone bought just the glass (not the glass/backing plate combo) from any of the aftermarket suppliers on eBay or elsewhere? Wondering about their quality?
Hit an owl/bird at 70MPH last night. Came flying across the road angled at me and did a glancing blow off the driver's side mirror. Broke the mirror glass, popped the backing place off the actuator (was hanging by the heater wires) and rotated the mirror assembly inward, but nothing else was damaged. No blood, no feathers, nothing. Have no idea what happened to the bird. It was huge, at least 4 ft wing span...
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
