Direction of slotted and drilled rotors
Old Sep 5, 2010 | 01:02 AM
drbk563's Avatar
Hi,
I am going to be installing some new rotors this week. The rotors are both slotted and drilled. I just wanted to know in which direction should the rotors be facing?
Old Sep 5, 2010 | 07:01 AM
Turbonut's Avatar
http://www.stoptech.com/tech_info/faqs.shtml#16
Old Sep 5, 2010 | 07:43 AM
drbk563's Avatar
Thank you for the article Turbonut.
Old Sep 5, 2010 | 10:06 AM
I hate cars's Avatar
I don't know why but Rotoras are different than everyone else.
Always give priority to the internal vanes if directional. They pull from the center to the outside.
Usually the outside slots rotate in such a way that the slot would fling debris away from the rotor toward the outside. Rotoras go with the external slots where they would channel stuff inward toward the hub. I've had people tell me I have the rotors on the wrong side but they're on right. I honestly don't think it matters much on the outside but it still looks weird.
Old Sep 5, 2010 | 12:02 PM
Bearcat94's Avatar
AZ Community Team
Aren't the rotors marked "L" & "R"?
Old Sep 5, 2010 | 12:13 PM
01tl4tl's Avatar
all directional rotors will have marking on the center hub ,,something like L or R to indicate which side of the car--from driver viewpoint, L= driver
or an arrow which points to the front of the car ------>
dont forget the synthetic caliper grease for pad backs and end tabs (if applicable)
Old Sep 5, 2010 | 12:15 PM
01tl4tl's Avatar
RB seems opposite to others for the side vanes direction
but its inner curved vanes serve to extract heat from the center hub- where its hottest
Old Sep 5, 2010 | 12:19 PM
01tl4tl's Avatar
purpose of the side vanes is to allow an escape path for expanding pad gasses under hard use
In some cases in can be enough pressure (heated air expands you know) to push the pads OFF the caliper!! while still maintaining your foot hard on the pedal--pretty scary feeling
So the vanes simply allow an expansion area and escape route
notice how some makers go to the edge, and others are mid-set on the face
They serve the extra function of micro-scraping the pads on application so they are always clean and at full contact ability to rotor
Old Sep 6, 2010 | 06:45 AM
drbk563's Avatar
01tl4tl,
The box which the rotors came in do have a making on the the box left or right. I just did not know from which perspective the rotors where marked. Thank you for the clarification.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
hashbrown
Sep 29, 2015 12:13 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
