Delay going from R-D
Old Mar 13, 2020 | 09:19 AM
kpayne111's Avatar
My 04 takes a little bit switching between r and d, about a second, maybe closer to 2. It's got 370k kms on it. Trans works perfectly fine otherwise but has the usual whine when accelerating in all gears. I did a 3qt fluid change with dw1 at 350k (dont think it has ever had a fluid change). Wondering if there is some stuff I could try or is this normal?
Old Mar 16, 2020 | 08:45 AM
LoveMyTL-S's Avatar
Anyone??
Old Mar 17, 2020 | 09:18 AM
GhostTL09's Avatar
sounds normal to me unfortunately , especially if original tranny from 04
maybe reset your ECU
Old Mar 18, 2020 | 06:59 PM
kpayne111's Avatar
I have done that before, didnt change shifting into drive but definitely prefer the way it drives, I usually just use manual shift since I know how I want the car to drive :P
I did the 3L change 6 months ago and I think it's never been changed otherwise, so after doing research I'm thinking the fluid is just very spent and causing this
Old Mar 18, 2020 | 07:22 PM
peter6's Avatar
Mine ('08 TL with 115k) does the same. It was doing it ever since I bough the car with ~76k and two other TL that I test drove were doing it. Switches helped with shifts, but didn't do anything to the delayed shift to D. My ATF is in pretty good shape. I probably ran like ~15qt through it since I bought it.
My buddys' '05 RL does the same. I believe those cars are just like that. Don't think you can do anything. Just keep up with maintenance.
yaze21
May 15, 2009 05:54 PM
JaredGMS
2G CL Transmission Recall Q & A
Nov 4, 2004 05:04 PM
gregtomash
May 21, 2004 04:29 PM
blazerbob1
Jun 9, 2002 08:22 PM
