Defroster Smell
Old Dec 21, 2020 | 02:59 PM
E39's Avatar
E39
Defroster Smell
I have this weird bad smell only when I turn the front defroster on. If I have the heat on any other vent I don’t really smell anything bad but if I switch to defrost it smells. I changed the cabin air filter and tried disinfecting the system through the fresh air vents as much as possible with no results.
Im hoping it’s not a heater core leak as I don’t have any issues with heating. But can a small enough leak cause smells only through defrost?
Old Dec 21, 2020 | 05:17 PM
vpasla1's Avatar
Your compressor kicks on for defrost, and not the other modes of heat, so I would start there.
Old Dec 21, 2020 | 06:04 PM
E39's Avatar
E39
The smell isn’t like a mechanical burning type smell. It’s more of like a vinegary type smell hard to describe so I’m not sure a fault of some kind in the compressor would ever make for a smell like it.
Old Dec 28, 2020 | 11:33 AM
Pair of TLs's Avatar
Yes.
Old Dec 28, 2020 | 02:34 PM
E39's Avatar
E39
Originally Posted by Pair of TLs
Yes.
Is there a way to diagnose a leaky heater core? Wouldn’t the smell issue be present when the heat is on in other vent modes since coolant is circulating through the heater core then?
Old Dec 29, 2020 | 08:47 AM
Ted Kief's Avatar
Check the carpet on the passenger side and see if its wet.
Old Jan 9, 2021 | 08:54 PM
WDPanda's Avatar
Probably mold/mildew on the evaporator.
lysol helps for a bit. Sprayed into intake vents at windshield cowl.
Rob Thompson
Dec 27, 2020 07:23 PM
cougar hunter
3G MDX (2014-2020)
Aug 31, 2020 02:07 PM
Tadeo
ZDX
Aug 5, 2016 02:56 PM
guojunmai
1G TSX Problems & Fixes
Aug 3, 2011 10:03 PM
andrewz182
May 6, 2009 10:10 PM
