Dead TL
Old Mar 5, 2020 | 01:50 AM
Natasha Beltran's Avatar
3rd Gear
Dead TL
i need help ! My acura dead i cant get it to start i thought it was my altenator went and bought a new one replaced it i also bought a car battery and its still dead. Every light on my dashboard is off doesnt turn or nothing. Wen i turn the switch off the green key light blinks 5 times what should i do replace the starter or what could it be?
Old Mar 5, 2020 | 02:25 AM
El_Cheapo's Avatar
Does it crank?
Security will only cut off fuel. It will still crank.
Old Mar 5, 2020 | 03:57 AM
3rd Gear
Originally Posted by El_Cheapo
Does it crank?
no doesnt crank or turn
Old Mar 6, 2020 | 02:01 AM
Will Y.'s Avatar
Registered but harmless
Sounds like a key immobilizer issue, since the green key symbol in the dash flashes and there is no ignition.
Try another key if you have one.
You'll need a locksmith or dealer to reprogram the key that's not recognized.
Old Mar 6, 2020 | 08:15 AM
peter6's Avatar
Like El_Cheapo wrote, immobilizer would cut fuel pump. Car would still crank and all the "lights" would still work.
Check fuses and make sure that battery cables are in good condition. They like to corrode internally, where it's hard to see, and then it causes all kinds of problems. You need to start somewhere.
Old Mar 6, 2020 | 09:01 AM
El_Cheapo's Avatar
peter6, people on here keep assuming it's the immobilizer for some reason.
I agree with peter6. Check the fuses, power and ground cables first.
Also, can you communicate with the PCM with a scanner?
Old Oct 9, 2022 | 10:25 PM
El_Cheapo's Avatar
@Natasha Beltran Did you fix it?
Old Oct 10, 2022 | 01:44 PM
3rd Gear
yes i fixed it it was my starter !!!
mendozad
Oct 10, 2019 08:42 AM
jon.mar27
Jan 27, 2017 06:32 AM
acuradfigueroa117
Nov 15, 2010 02:04 PM
regie
1G TL (1996-1998)
Feb 11, 2008 09:04 PM
agranado
Apr 27, 2006 03:33 PM
