Dashboard Click
Old Nov 8, 2007 | 06:39 AM
bhaubold's Avatar
Dashboard Click
We have an 04 TL AT with 55000 miles. All of a sudden it started this click noise when you start from a complete stop. It seems to be coming from the area around the radio. When I start from a stop, I hear this click, almost like a big clock ticking. one click. Then when I stop I also hear one click, not as loud as the starting click. This happens every time I start to move or stop.
Anyone have a clue? The car is out of warranty, so I guess it's my problem.
Thanks,
Bob
Old Nov 8, 2007 | 07:07 AM
WDP-Acura TL's Avatar
I have a clicking/popping noise when I accelerate from a stand still. I had thge dealership look at it the replaced something called a tire rod end. It was short lived, not it sounds like noise is coming from the front and rear. After I have driven the car for a good 15 minutes the noise stops. It seems to be temporary, but when I park my car for more than 30 minutes and drive it again it starts over.
I got over it.
Old Nov 8, 2007 | 10:24 AM
bhaubold's Avatar
The noise I'm hearing is coming from the dash area.
Old Nov 8, 2007 | 10:50 AM
JDM5lugHatch's Avatar
Now with i-Vtec
hmmm.... do you have anything rolling around in one of the cubby holes or glove box that may have slightly shifted? could also be your climate control making the noise. If I could hear it in the car I could probably tell you what it is. But I'm on the "right" coast...
Old Nov 8, 2007 | 11:13 AM
bhaubold's Avatar
I've checked all the cubbys for something loose. Nothing. it almost sounds like a switch that goes on and off. Very strange. It does happen everytime the car starts to move or stops.
Old Nov 8, 2007 | 11:15 AM
Now with i-Vtec
next time you are in teh car turn the climate control completely off along with the radio. see if it still happens.
Old Nov 8, 2007 | 06:15 PM
bhaubold's Avatar
Climate control off, radio off, still happens. Everytime it's the exact same thing. On Monday, I'm going to bring it to the dealer. See if maybe they will good will the repair. Also have a right rear speaker buzz that is very annoying.
This car has been great to drive. But the rattles and the noises are about to drive me away.
Thanks for your help,
Bob
Old Nov 8, 2007 | 06:33 PM
Now with i-Vtec
Bob
No problem. Good luck with it.
Old Nov 10, 2007 | 04:26 PM
bhaubold's Avatar
Found out today, the clicking is coming from under the shift lever plate. Not sure how to remove the plate (silver plastic cover) but, it sounds like it's right under the cover. The search continues.
Old Jan 23, 2008 | 10:01 AM
hynos's Avatar
bhaubold, i have exactly same problem as your, did u find a solution? thanks
Old Jan 23, 2008 | 11:10 AM
vinnier6's Avatar
the trim ring around the shifter comes right off, just stick your finger nails under it and pry it up...i retrimmed mine with some new felt tape and put it back on...i also put some around the the silver trim part that the trim ring butts up against toward the rear...that also helped my noise...
Old Jan 23, 2008 | 04:22 PM
libert69's Avatar
18psi
ive had that noise for as long as i can remember in my 04 tl. i found out it was the relay that allows you to shift to park/reverse from drive or vice versa when applying the brake pedal
like most problems with this car, the dealership told me it was "normal"
Biggie_B
May 27, 2025 05:51 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
