D light keeps flashing
Hey guys my D light keeps on flashing (i have a 07 tl-s) and I took it to the dealer but they have no idea, They recently did a tranny flush but it still didnt fix it..
I believe it is because of the 3rd gear because whenever i floor it the D light starts flashing and also when im going 65 mph or w.e and I throw it to 3 and accelerate it will quickly shift to 4th (in tiptronic)
AZ Community Team
Received 7,771 Likes
Flashing "D" is a tranny fault isn't it? It was in the 2G TL. Double check the owners manual to see if it's in there.
Should throw a code of some sort, I think. Try another dealer.
Yep:
Owners Manual, Page 253 - https://techinfo.honda.com/rjanisis/...707O00253A.pdf
The "D" should NOT flash. Period.
Yep:
The ‘‘D’’ indicator comes on for a
few seconds when you turn the
ignition switch to the ON (II)
position. If it flashes while driving (in
any shift position), it indicates a
possible problem in the transmission.
Sounds like 4th gear pressure switch is bad or dirty. Check out this thread:
https://acurazine.com/forums/showthr...light=Flashing
It should be repaired under warranty. Good luck.
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
Greengecko
09-16-2015 08:19 PM
HeloDown
09-08-2015 06:51 PM
