CV axle replacement
CV axle replacement
getting mine changed soon both sides Ive did a bunch of research I guess im mainly looking for one that has a dampener on it which the advanced auto parts stores dont have anyone have any experience with these first equipment quality axles
2004-2008 Acura TL Axle Assembly - Driveshaft & Axle - First Equipment Quality, Right 04-08 TL Axle Assembly - 17777-01094538 - PartsGeek
They come with a year warranty as well thanks in advance
I suspect you won't find many users that have experience with the axles you posted so I just linked you to axles that many members have had success with including myself. My bad. Good luck with it if you decide to go that route.
On the subject, I have a 2004 TL with automatic trans that I'm having a hell of a time removing the axle from the trans case. My Haynes manual is worthless and I'm not sure of this unit has a intermediate shaft that I should be disconnecting or with the right amount of pressure and leverage will it pop out of the trans case? This just about has me beat and I can get good instructions or a youtube video explaining the process. Any help offered is Greatly! appreciated.
I just ordered one passenger OEM axle. Cheapest Honda would give me is $350 CDN. After reading about people having issues with aftermarket, i do not want the headache and added time and labour to correct faulty replacements.
I will see how much longer the driver's side lasts before replacing. Normally I'd replace in pairs but I'm curious to see how much longer it will last.
CdTriX
Apr 30, 2016 05:02 PM
