Creaky Pass Seat
Old 03-19-2007 | 06:28 PM
KeithL's Avatar
Creaky Pass Seat
Have 07 TL (noticed it on my friends 07 TL as well) and mostly when no one is in the seat I notice a creaky noise when the care is accelerating or decelerating. If I move the pass seat all the way forward it does nto happen. I can sometime make it happed by lifting up on the seat form the bottom side. I'm wondering if anyone else had/has this and has fixed it. I am thinking maybe pulling out the seat, and re-fastening it, but it souds plasticy so I'm thinking the trim along the bootom right side is the culprit.
Old 03-19-2007 | 08:39 PM
lusid's Avatar
FTW
I used search function keyword "seat" and I got this link.
https://acurazine.com/forums/audio-video-electronics-navigation-22/infinity-perfect-6-1-does-not-fit-125087/
Try to do the same for all other issues because if you have the issue chances are someone else does too
Old 03-20-2007 | 06:07 PM
KeithL's Avatar
https://acurazine.com/forums/showthread.php?t=125087
I saw that one, but mine is more like a creak and not the same at least as he discribes it, but I may look into that as it is not that difficult to rule out.
Old 03-20-2007 | 09:14 PM
lusid's Avatar
FTW
You must perform the hump test and report back.
Old 03-21-2007 | 02:26 AM
rventu's Avatar
Same issue here.... actually mine has been gone now for two weeks so far after applying silicon spray on the lower track underneath, left hand side. No joke...my 06 had the same issue.
Old 03-21-2007 | 01:11 PM
drmwvr's Avatar
Take it to the dealer. I had this same problem with my '06 and they replaced the seat frame. Problem is gone now.
Old 03-24-2007 | 10:26 PM
i sprayed wd40 on the pass seat left side track on my 07 type s and creak went away immediately. Hope it lasts.
Old 03-25-2007 | 12:10 AM
havokgroup's Avatar
The seat noise can come from alot of different areas. At the shop I have applied a silcone spray on the seat tracks. Most of the time I have removed the 14mm bolts that holds the seat down, and apply a thin foam tape to the contact area between the seat tracks and the body itself.
MrHeeltoe
20
02-23-2023 02:54 PM
tsx_boy
12-13-2019 09:33 PM
MrHeeltoe
09-29-2015 11:43 PM
hashbrown
09-29-2015 01:13 PM
MrHeeltoe
09-28-2015 06:43 PM
Quick Reply: Creaky Pass Seat
