Crank Pulley Squealing
Old Apr 8, 2022 | 10:27 AM
CenturionTL's Avatar
My 05 Tl crank pulley is squealing upon vehicle start for about 5 minutes.
I sprayed it down with wd-40 and then sprayed white grease on it, it went away, now it came back.
They pulley does not wobble.
Does the crank pulley have a bearing in it?
Old Apr 8, 2022 | 01:17 PM
The pulley is not wobbling or loose. It has a has a rubber/elastomer bushing and no bearing?
I don't know why its squealing.
I just pressure washed the pulley all around it. Hopefully this washed away the problem - if it is able to be washed away.
Old Apr 8, 2022 | 07:32 PM
csmeance's Avatar
did you get grease on the belt? I would take it off, clean all the pulleys and make sure the belt has no oil. You may need to throw on a new belt if the old one is contaminated.
Old Apr 9, 2022 | 09:51 AM
^^ I took the passenger wheel off and greased it. I didn't get any grease on the belt.
I took the belt off afterwards and pressure washed the crank pulley it when it started to squeal again.
Old Apr 9, 2022 | 10:14 AM
the power wash didn't work. it's squealing.......
zeta
Dec 8, 2022 12:52 AM
CenturionTL
Mar 30, 2022 06:32 AM
TylerT
26
Feb 7, 2008 04:53 PM
superchargedcls
Aug 7, 2005 10:09 AM
TopGum
Sep 13, 2002 01:00 AM
