Coolant in reservoir is always low?
Old Jan 10, 2010 | 11:20 AM
kvnly2's Avatar
The coolant in the reservoir will be low and I'll fill it up halfway. Drive as usual for a week and check again and its back at low. I checked for any signs on my garage floor but don't see any. What I do see is when I get to work, I'll check under the engine and I'll see some kind of liquid (probably coolant) but in a tiny puddle. What other signs should I check for ? what could it be? Thanks in advance guys and its a 2006.
Old Jan 10, 2010 | 01:24 PM
wahshi's Avatar
My TL loves summer
Did you check for any signs of cracks on the reservoir itself? It could be puddling up on covering underneath the car and not making it to the ground. Another explanation is that you couldve been low on coolant and it could be in the core.
Old Jan 10, 2010 | 07:47 PM
jayare627's Avatar
mine's always been low, I fill it ever few months with a little. I know it's not supposed to do it, and it's not leaking, haven't notice any signs of it burning off on the engine or internally. So I just kind of accept it unfortunately.
Old Jan 10, 2010 | 08:37 PM
Joe Foe from Buffalo's Avatar
On my 05 it go low also after a while. See no leaks also.
Old Jan 10, 2010 | 09:33 PM
libert69's Avatar
18psi
my 04 has been like that for 4 years and i have no problems. after a few weeks the reservoir go down to the lower line
Old Jan 12, 2010 | 11:10 AM
Majofo's Avatar
Necessary question.. are you checking the res when the car has been off for several hours?
Old Jan 12, 2010 | 11:14 AM
I for one can say yes.
Old Jan 12, 2010 | 11:19 AM
Majofo's Avatar
Then check the oil, your passenger side carpet, and your firewall. If it's leaking somewhere it'll be noticeable. Either your oil will be milky, your carpet will be damp or there'll be dried coolant all over your rear mount, brake & fuel lines.
Old Jan 12, 2010 | 11:28 AM
Will do asap. But can say all ready nothing is on carpet.
Old Jan 12, 2010 | 12:02 PM
Just checked,No evidence on my car of a leak.
Old Jan 12, 2010 | 01:09 PM
xmrgoodcatx's Avatar
If you want to be sure your coolant system has no leaks, go to Autozone and borrow a coolant pressure tester. It is basically a pump with a psi gauge. You pressurize the system to what the psi reads on the radiator cap. If the needle on the gauge stays solid then you have no leaks, if the needle goes down however then you have a leak. While the needle is going down check for the leak.
Worse case is the head gasket is bad and the coolant is leaking back into the block. You can tell this by looking underneath the oil cap or shining a light into the fill whole. If you see a dirty milky build up then you know where your coolant has been going. This is usually not the case if it has been happening for while since you would probably have noticed your engine knocking. I know first hand since I blew a 5.7l this way and seen it a couple times when I worked at a shop. Every day for a couple months the coolant would be low,the engine started knocking, I went to drain the oil and it looked like chocolate milk.
Old Jan 12, 2010 | 01:20 PM
Good info, thank you.
Old Jan 12, 2010 | 02:56 PM
I hate cars's Avatar
Agreed. And to add to that, check right around the rubber hose that goes to the reservior near the radiator cap. Mine leaked when brand new. Not enough to see unless you were really looking for it. A small ziptie cured it.
As Mojofo said, check when dead cold like first thing in the morning or when hot as soon as you shut it off but make it consistant. If can vary by 2" from cold to hot.
Old Jan 12, 2010 | 05:57 PM
Will Y.'s Avatar
Registered but harmless
Also remember to test the radiator cap with the pressure tester.
I had a bad cap once, but it was the last thing I checked.
Old Jan 15, 2010 | 04:22 PM
kvnly2's Avatar
so....i have spent the last week every morning when the engine is dead cold, and as soon as i got home everyday. Have checked my oil, carpet, and everything mentioned on here. BUT i did find a problem. the reservoir is made of plastic and the cap in which covers up the hole where you pour the coolant in has cracked on top. it still tightens but there is a tiny crack in the cap. but how does it explain why im losing coolant ? its on the very top of the reservoir so its not leaking out,is it?
Old Jan 15, 2010 | 04:50 PM
There's some evaporation with coolant. It's not as much as straight water but a crack could be enough to lose a few ounces of hot water in a week.
Old Jan 24, 2010 | 11:57 AM
acura_dipset_tl's Avatar
AM To WDP In My Garage
WOW that's scary because mine has been showing low coolant In the reservoir and I hear some kind of knocking on the engine but someone told me that I needed my valves adjusted. Hope that all it needs
Any suggestions on how to tell the difference on the knocking?
Old Jan 28, 2010 | 01:20 AM
rollaaa's Avatar
I just noticed this today as well. I have the crack in the reservoir cap. My coolant gets low pretty quick too and I didn't see any leaks.
Anyone have the part number for this? or would some super glue suffice?
Old Jan 28, 2010 | 02:06 AM
libert69's Avatar
18psi
http://www.hondapartsunlimited.com/i...RESERVE%20TANK
part #2
002 19102-PM5-A00 CAP, RESERVE TANK 2004 TL 1.45 1.09
you could just goto a junkyard and find one off any honda/acura model. they are almost all exactly the same. my original cracked and im using a cap from a honda odyssey
Old Jan 28, 2010 | 11:27 AM
NedShneebly's Avatar
practicing nihilist
mine gets low from time to time, as well. maybe twice in 3 years I've added. I'll check the cap but sounds like it's somewhat consistent.
Old Jul 27, 2021 | 09:38 PM
94Auto's Avatar
Was having this issue in my 08 and sure enough it was a cracked reservoir cap. Replaced with a new one and now the coolant stays at a consistent level
(Holy thread bump batman)
08KBP_VA
Oct 22, 2019 01:55 PM
spudweb
May 22, 2016 02:39 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
