Coolant leaking
Old Aug 7, 2011 | 02:44 AM
gotkilled's Avatar
NBP is a pain...
Coolant leaking
While doing the throttle body bypass, i noticed the water pump area outlet to the throttle body had splotches of dried, green coolant.
I checked the hose and it looked fine but the coolant was a very weird pasty, green slime. Hose was attached snug as well. What could the issue? I certainly hope it's not that the outlet has a hair line crack somewhere...
Should I just use one of those Barr's Stop Leak products?
Old Aug 7, 2011 | 03:02 PM
csmeance's Avatar
don't use a stop leak product. Those are VERY bad and can cause a ton of issues!
Clean it up with a bit of brake cleaner and monitor it so you can figure out where it's coming from.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
