Coolant leak from behind engine
Old Oct 26, 2021 | 07:09 PM
Mac81's Avatar
Hi guys, I started losing coolant a few days ago from a dry rotted hose. So I replaced hose thinking the problem was finished when I started noticing a small drip from behind. I havnt been able to get under car to find as of yet but anyone have experience in this issue?
Old Oct 27, 2021 | 09:10 AM
TheSauceBoss's Avatar
There are a variety of paths your cooling system uses around the engine. It is impossible for us to speculate without you narrowing it down a little bit. Try to look around in there, take pictures. Evidence of coolant will be relatively easy to find, whether it be the coolant itself dripping out of somewhere, or dried coolant that has discolored on hoses.
If it's towards the rear of the engine, it could be something related to your heater core, but without further info, it's just a guess. I'd look back on the hose you replaced and check all connections, along with any upstream/downstream connectors attached to that hose.
Barmaley
Jul 8, 2017 02:15 AM
acura1999tl
Jan 30, 2016 02:52 PM
CaliBud916
Sep 20, 2014 10:30 PM
thewrangler99
Aug 13, 2010 07:11 PM
Sarlacc
Jul 1, 2003 05:57 PM
