Comptech exhaust
Comptech exhaust
I bought a used Comptech exhaust and one muffler has a broken weld, is there anyway to fix this? Will Comptech weld it back as a courtesy to keep a good reputation and help a man out?
Not sure about CT doing it since you bought it used (warranties transferring and all that), but it's worth a shot. Easier solution may be to take it to a mechanic and get a quote on how much he'll charge to fix/redo the weld.
Take it to a local muffler shop. They'll probably fix it for 20 dollars.
def take it to the local muffler shop comptech won't help you, i am not impressed with comptech's quality especially there welds I had 2 completely fail on me causing the mid pipe to drop. I was on vacation in new york city it was a huge hassle. Basically the two pieces completely rusted off on the joint right before the split that has the clamp. This exhaust was only like three years old. I could never get a hold of anyone at comptech to try to help me. I ended up just using a stainless clamp to join the two pieces it seems to be going strong for about 6 months now. I didn't want to have it welded since it would be impossible to install like that since the exhaust would be almost one big piece and getting a shop to install a joint would be more trouble and they would prly fuck it up... the clamp was only like 6 bucks from napa its the same as what you see on big rigs to connect their pipe to the muffler.
joflewbyu2
10-08-2015 11:16 AM
