Common Acura overheating problem.
Subscribe
Aug 1, 2016 | 10:13 AM
I posted this in the TL community:
https://acurazine.com/forums/3g-tl-p.../#post15815306
I suspect, but don't know, that this fan relay problem is common to many other models and years.
They had a TSB covering the relay but in a different application.
Failure of this relay can lead to high engine temps in traffic and blown head gaskets.
I am VERY HAPPY I figured this out thanks to the Acurazine forums.
I just want to give back. How would this problem be posted in multiple forums? If I had help from owners of other models I could modify my write up.
Reply 0
Aug 5, 2016 | 03:18 PM
I moved this thread from the User Help Forum, where it really shouldn't have been posted but I can understand why you did it, to Car Talk and made it a sticky thread.
Let's see how this works. You haven't received any replies here so we can't do any worse moving it.
Reply 1
Jan 16, 2019 | 05:02 AM
What type of relay is it; a solid state relay or a mechanical relay?
What is failing. All a relay is a switch. Is it not being switched by a temperature sensor?
Reply 0
Jan 16, 2019 | 09:31 AM
Unstuck and moved to 3G TL.
@Tech FYI
Reply 0
Subscribe
