Clutch Case drain broke!! HELP!
Old Feb 17, 2012 | 09:04 PM
RJNN TL's Avatar
Ryan's loving his ATLP TL
I need help...Real help! So....And I just got done draining the transmission fluid when THIS happened.. WHAT exactly does everyone suggest I do? Obviously the car is undriveable without this fixed.
Old Feb 17, 2012 | 09:06 PM
RJNN TL's Avatar
I never even torqued it fully. The thing literally just broke....
Old Feb 17, 2012 | 09:07 PM
truonghthe's Avatar
god dam you must have alot of muscle then.
Old Feb 17, 2012 | 09:08 PM
RJNN TL's Avatar
Well I need a solution to this problem. Anyone have a similar experience? Ideas?
Old Feb 17, 2012 | 09:33 PM
RJNN TL's Avatar
....Anyone?
Old Feb 17, 2012 | 09:59 PM
RJNN TL's Avatar
Im starting to think.. This may be a JB Weld Situation? Look at this picture. When under some pressure it stays fine with the bolt screwed in. Now what if I JB Welded the piece back on? I'd love some feedback.
Old Feb 17, 2012 | 10:00 PM
RJNN TL's Avatar
Even with it on as I do with a small sample of Fluid in the tranny it begins to leak where the crack is.
Old Feb 18, 2012 | 01:21 AM
VanyDotK's Avatar
Holy shit, you must be a strong mofo. I'm pretty sure you're going to have to replace the case?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Part number 003, I'm not sure, I would verify with a profesisonal mechanic to be sure.
Old Feb 18, 2012 | 01:55 AM
RJNN TL's Avatar
Yeah I looked into that. Im assuming this needs a legit weld done. But I am trying JB Weld first. Will be back tomorrow around 9PM to give full idea if it worked. Even so. I will look into fixing this permanently. IF this JB doesn't work.
Old Feb 18, 2012 | 04:09 AM
RJNN TL's Avatar
So I JB Welded it, pictures are bellow. From the sounds of reviews and past experiences. Who knows it may work. I sure hope it does haha.. *Facepalms*
(I put the light real close so it heats it up, so by about 15Hrs, I'll check and see if it holds the bolt fine.)
(Good ol JB Weld, lets see if it works: Update tomorrow)
Old Feb 18, 2012 | 06:20 AM
Turbonut's Avatar
Would have had it welded then tapped.
Looks as if you have JB Weld inside and within the threads, so you may have a hard time inserting the drain plug bolt, and also, when doing so it will cause undo pressure from the inside and may push the broken piece outward. May want to run a tap down the threads first. Good luck.
Old Feb 18, 2012 | 08:58 AM
johnny3's Avatar
Yes, run a tap into it first.
Old Feb 18, 2012 | 10:01 AM
RJNN TL's Avatar
What do you mean by a tap? And I have put the bolt inside and it screws in fine. Im giving it the full 15-24hrs. So we'll go from there if so. Ive checked it and so far it's extremely tight.
Old Feb 18, 2012 | 10:30 AM
KN_TL's Avatar
I would start thinking about a replacement though. Either a case or a used tranny. You could check with Ack05 (I think that's his name) to see what he's got for a used 6MT.
I personally wouldn't trust that to last over the long haul.
Old Feb 18, 2012 | 11:26 AM
VanyDotK's Avatar
I'd be worried with all the heat.. metal expanding and shrinking..
Old Feb 18, 2012 | 01:41 PM
johnny3's Avatar
A "tap" is the tool that cut the threads into the housing as it was being manufactured. The tap would "cut" the JB weld out, so the drain bolt would not "push out" the repaired area (open the crack again.)
Old Feb 18, 2012 | 04:55 PM
RJNN TL's Avatar
Where would I go about finding a tap? So what, the idea is to fill the boll with some JB then cut it with the tap? I don't think it's necessary to replace the whole darn tranny because of this or the case. I'll just probably have to have it professionally welded back on if JB doesn't work.
Old Feb 21, 2012 | 12:54 AM
RJNN TL's Avatar
So with dripping slowly I drove 15 minutes to the nearest Auto Shop that I know the guy. He's taking it and will see what he can do with it. They may reweld or work on making a better JB option. We'll see what happens. Shitty situation..
Old Mar 5, 2012 | 12:16 PM
triax37's Avatar
Any update on this? I changed my MT fluid the same day I saw this post, so it was a good reminder to be extra cautious when torquing it down.
Old Mar 5, 2012 | 01:28 PM
pohljm's Avatar
Damn! If that fails while driving you will loose all fluid before you know it! I would not trust that except to get to a welder or mechanic. Have it welded or replace the case for sure.
Old Mar 5, 2012 | 05:33 PM
94eg!'s Avatar
#1 Super Guy!
The clutch case is about $361. Too bad it would cost a fortune to have all the work done. Definitely a possibility for the DIY type though.
Old Mar 6, 2012 | 05:01 AM
gen2gsr's Avatar
I have ran into this before on a integra trans, I used the jb weld for a while until it started to leak again then just replaced the case. Im sure the tl trans is just like the integra where you will have to re-shim the mainshaft and diff if you do get a new case.
SidhuSaaB
May 30, 2020 12:40 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
knight rider
Mar 4, 2016 08:59 AM
polish_pat
Sep 30, 2015 12:22 PM
hpfiend
Sep 27, 2015 06:59 AM
