Clutch cable maybe?
Old Aug 10, 2017 | 10:57 PM
avery herbst's Avatar
6th Gear
Clutch cable maybe?
Went to pull out of a stop, heard a snap or breaking noise, car wouldn't move after that. The clutch felt harder and wouldn't stall out if I tried. It's a 06 TL could it just be the clutch cable it's self or worse. How bad will it be to fix?
-Thanks guys
Old Aug 11, 2017 | 12:08 AM
thisaznboi88's Avatar
its hydraulic clutch. so unless the clutch lines are damage. It might be the shifter cable
Old Aug 11, 2017 | 08:41 AM
Jackass's Avatar
Or an axle? How big of a snap noise was it? With the car off, can you move the shifter between gears?
Old Aug 11, 2017 | 11:41 AM
6th Gear
It still shifts between gears and i didn't see anything hanging or leaking. I called a shop he said the pressure plate coulda broke and the clutch would have to be replaced. If I'm lucky it's could be a link in the shifter.
Old Aug 11, 2017 | 11:42 AM
Or axle
Old Aug 11, 2017 | 12:27 PM
musiclevelz5's Avatar
Is the car able to accelerate or not? I agree check the axles.
Old Aug 11, 2017 | 12:46 PM
6th Gear
Well let's put it this way, I can put it in any gear with the engine running without using the clutch foot on the gas and nothing happens. The car will not stall out even if I try.
Old Aug 11, 2017 | 12:53 PM
BreezyTL's Avatar
Car turns on tho? Assuming it does since you said you can put it in any gear while running. Wouldn't that rule out the clutch?
Old Aug 11, 2017 | 01:01 PM
6th Gear
Honestly I'm not sure. It's was already running when I tried everything but I didn't try to shut it off and back on.
Old Aug 11, 2017 | 01:33 PM
BreezyTL's Avatar
So it's still running?
Old Aug 11, 2017 | 02:50 PM
6th Gear
Nah I pushed it into a safe spot and turned it off and left it there. Haven't been able to do much with it today due to work. I have a buddy going to try and start it up now but I'll probably end up just getting it towed to a shop that specializes in transmission services
Old Aug 11, 2017 | 03:03 PM
WDPanda's Avatar
What if you need a shop that specializes in axles?
Old Aug 11, 2017 | 03:27 PM
Jackass's Avatar
Hold on....Engine running, he can run through the gears without touching the clutch...that isn't an axle issue. This would be transmission related...so either the clutch itself is not engaging for one reason or another...or the shifter isn't shifting for one reason or another.
Old Aug 11, 2017 | 03:48 PM
6th Gear
Snapped the passenger side axle.
Old Aug 11, 2017 | 06:41 PM
Jackass's Avatar
Interesting....not sure how you were able to freely shift gears without the clutch if it is just the axle.
Great for you overall though. At least a somewhat simple and not stupdily costly repair.
