Clunk noise when accelerating after slowing down
Old Apr 19, 2018 | 04:13 PM
stevemk07's Avatar
08 auto 260k kms.
My car has started making a clunk noise whuch seems to he coming from the front passenger corner, likely suspension related but I cannot identify the problem. In the past 6 montys I have replaced the side amd front engine mounts (noise was not present before or after the change, til now) replaced both dront strut assemblies amd chamged the front passenger end link. Any ideas what it might be?
I am thinking axle may be rusted down so theres some play there but not really sure....
It is a muted knock sound.... If I accelerate lightly I dont hear it but if I give it a bit of gas you can hear it amd it doesnt come back again until i slow right dow amd then give it gas again. Turning doesnt seem to have any effect on the noise being there or notnbeing there.
Any ideas?
Old Apr 19, 2018 | 04:15 PM
stevemk07's Avatar
By the way I retightened the fork bolt and did have the hub at ride height. Noise still there. Bushings look good except the fork bolt one has a small crack. Maybe that is all it is...
Old Apr 19, 2018 | 07:39 PM
stevemk07's Avatar
Old Apr 20, 2018 | 02:59 PM
stevemk07's Avatar
Well I cant find anything wrong... Would a loose ball joint make that noise? Think I am gonna have to just start replacing things and something fixes it.
Old Apr 21, 2018 | 10:59 AM
stevemk07's Avatar
Nvm u guys suck
Old Apr 21, 2018 | 06:15 PM
Joecop67's Avatar
Maybe no one has an answer.
Old Apr 22, 2018 | 06:45 AM
tpz76's Avatar
I have the same noise on mine, have yet to isolate the noise.
Old Apr 22, 2018 | 09:16 AM
quantum7's Avatar
this is the problem with suspension noises.....you chase the noise with parts and end up spending a fortune. my car has a front end clunk and I have gotten 10 different answers from 10 different people.
Old Apr 23, 2018 | 09:35 AM
stevemk07's Avatar
I suppose no answer could be considered an answer
I will update if I figure it out
Makes sense
Alright guess Ill just have to take it all apart and have a better look...
Old Apr 25, 2018 | 01:21 AM
tpz76's Avatar
So this is the noise I have. It is a "pop" that occurs from takeoff or acceleration at low speeds. And sometimes it is a double pop, however so far this spring I am only hearing one pop. It is local to the center of the engine bay and I do not hear it every time I stop and take off, I hear it more so when the weather is warmer, and no that is not cause I have my windows open, I hardly heard it, if I heard it at all throughout the colder months. I also hear the noise sometimes as soon as I let off my brake pedal, hence giving me the idea that it has something to do with the brakes. Is yours a Type-S with brembo brakes? I have heard the hold down springs can make noise, but this theory goes out my window cause when I pull into my garage and apply heavy braking, I hear the same noise only 3 or 4 times with a ratcheting effect sound. I have been chasing this noise for the year I've had my TL, I have found several hits online with talks of bad axles, ball joints, brakes, stabilizer bar end links, axle nuts, axle splines.... the theories are endless, and no one has posted about ever finding a solution to the issue. I have new brake pad springs and pins I'm going to install soon and also going to replace the axle nuts. Prob not going to make a difference, but is worth a shot as maybe a fairly cheap fix. I will post my results soon. Until then, keep on looking and keep me posted if you find a solution.
Old Dec 13, 2018 | 11:19 PM
woodworkerii's Avatar
Did you ever find the fix?
Old Dec 15, 2018 | 03:40 AM
tpz76's Avatar
Nope!!!! Lol.
Old Dec 15, 2018 | 11:39 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Are we sure it isn't a bad engine mount or transmission mount?? Slowing down and then accelerating.............
Old Dec 15, 2018 | 01:11 PM
+1 on mounts
Old Dec 17, 2018 | 11:12 AM
tpz76's Avatar
I've already replaced the mounts. It isn't so much a clunk as it is a click. I'm leaning towards cv joint.
Old Dec 17, 2018 | 11:15 AM
Check your compliance bushings/ Lower control Arms and sway bar links
NerdO_TL
Feb 1, 2016 05:58 AM
RustyLogic
Mar 9, 2015 06:51 PM
jwskier187
May 22, 2009 06:15 PM
r3mix3r
Jul 20, 2004 06:04 PM
Speedy3.2CL-S
Feb 28, 2002 05:16 PM
