Clunk Issue
Old Jun 17, 2015 | 09:44 AM
EvilVirus's Avatar
Clunk Issue
When I put it into gear and start to drive off, there is a clunk noise once I let off the clutch. I can hear it twice and feel it in the pedals. As I change gears, seems less and cannot hear it at all. I have NO ISSUES when making turns, going over bumps, pulls, or low speed vibration. I do have vibration on the steering wheel if I am going about 65+; so the issue is in low speeds. Seems to be coming from the front driver side,
Searching around and trying to get a lead in the right direction; I came across these forums:
clicking/clunking when taking off and shifting into second - Honda-Tech
The infamous clunking noise... - Club RSX Message Board
Clunk going over bumps - Honda Accord Forum : V6 Performance Accord Forums
Suspension Mods:
A-Spec suspension
Fastline Compliance Bushing (note - I have never had an issue with these besides the squeak - fix)
XLR8 62a Front and Side Motor Mounts/OEM rear mount (All new)
Edit - I have inspected the ball joints, upper control arm, the shocks, endlinks, tie rods, front sway bar, transmission mounts, caliper......
Any advice and suggestions will be greatly appreciated.
Old Jun 22, 2015 | 01:56 PM
EvilVirus's Avatar
I found the issue
Old Jun 22, 2015 | 02:00 PM
polobunny's Avatar
Registered Bunny
For the record, what was it?
Old Jun 23, 2015 | 03:46 PM
gosharik12's Avatar
9th Gear
Side engine mount?
Old Jun 25, 2015 | 04:52 PM
EvilVirus's Avatar
Uh I guess it didn't post completely from my phone.
Anyway, the center mount bushings was missing a bolt and the other bolts were loose. I re-tighten all the suspension bolts in which I found that the upper control arm bolt was loose.
Overall check your bolts. I have been driving it for a couple of days and no more clunk noise.
snorf
Nov 4, 2019 06:44 AM
marcelft
Jul 10, 2018 06:17 PM
Frathora
Sep 28, 2015 11:29 PM
carz0159
Sep 20, 2015 06:11 PM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
