Climate controls, mirror adjustments not working!!
Cluster and other problems!!!
My 04 TL gauges, power windows, sunroof, adjustable mirrors, reverse lights, turn signals, and wipers all went out at the same time. No idea how but I need it fixed asap!! Either its a fuse I missed or a relay I can't find.
or the battery is bad? or the MICU
Stay Out Of the Left Lane
Received 1,245 Likes
Damn....would my best bet to look for a certain relay or relays that controls what's listed? Before I look to see what's going on with the MICU
Did you check the fuses in the under hood fuse box?
What did you do to get the clusters back? What have you tried or ruled out in the past month?
My climate control buttons nor my mirror adjust buttons are working. I have an 04 tl non nav. The buttons for my climate controls are lit but do not turn anything on. The display does not turn on either, but my radio display does. With that my outside temperature sensor aren't working. I'm not sure if that has anything to do wit my mirrors but they won't adjust wit the button. Wit that being said I'm wondering if there is a fuse or relay or maybe something I'm missing....PLZ HELP?!?! Its starting to get cold
Go through ALL your fuses with a multimeter in continuity mode.
Threads merged. no need to open up a new thread for the same issue.
There are fuses in the driver's side kick panel and in the hood, i believe some in the passenger kick panel as well.
