Climate control temperature value ignored
Old Sep 12, 2014 | 01:28 PM
pherbio's Avatar
The A/C blows cold when set to Low and the heater works great when set to High. Unfortunately, in order for it to work on any temperature in between, I have to go to the extreme, let it sit there for about 3 minutes, and then adjust the temperature.
For example, it's been mostly warm here the past few days, so I've been having the A/C on Low. This morning, it was a bit chillier than normal, so I wanted the temp set to around 75 degrees. If I just adjust it to 75 degrees, the temperature will continue to ignore my setting and blow at the Low temperature. I have to bring it up to High, let it run for 3 minutes, and then drop it down to around 80, let it sit there for 3 minutes before bringing it down to 75.
Any thoughts?
2008 Acura TL Type-S
79,000 miles
Old Sep 12, 2014 | 01:36 PM
are you using the auto setting?
Old Sep 12, 2014 | 01:40 PM
pherbio's Avatar
No
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
