Climate control problem?
Old Jul 25, 2014 | 10:40 AM
TacoBello's Avatar
My temperature setting in my [Canadian] car go:
Lo - 17....31 - Hi
It seems that my car only blows hot air when I put the temperature up to "Hi" in the car. If it is anything below that, between 31-17 degrees Celsius (sorry, Canadian car here), the air temperature is always the same and it blows cold.
There is no intermediate temps. It's like the heat doesn't change at all and only turns on when put to Hi. Is this normal? Has anyone else had this issue?
Sometimes it's a little cooler in the evenings and I'd like to have some heat on, but unless I crank it to Hi, I'm only left with cold air. As part of my recent major service, I had the thermostat and coolant replaced so I know there isn't an issue there.
Can anyone help??
Old Jul 26, 2014 | 12:09 PM
anagramjones's Avatar
I fixed this problem on my 07, I'm in Toronto. Search my posts, or I'll try to get you a link when I get to an actual computer
Old Jul 26, 2014 | 02:22 PM
TacoBello's Avatar
Thanks for the help!!
After reading through your thread, it looks like this is something that will take me a bit of time to get done, so I'll save it for a long weekend. I'm just glad I don't have to replace something super expensive!!!
Old Jul 26, 2014 | 09:17 PM
There's a long weekend coming up
When you screw the gears back in, don't make it too tight. Scroll through the temperature while looking at it move and adjust tension of the screws so that they let the gears move freely
Rachel Lu
Sep 27, 2015 09:53 AM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
