Climate control doesn't work but radio is working
Good morning guys,
I am having some challenges with the ac of my 2005 Acura tl. My ac stopped blowing cold air and I was doing some troubleshooting to find out if the problem was my compressor or just a relay or fuse. After attempting to force my compressor to start manually my climate control is not coming up. I tried to follow the normally steps advised by other users such as fuse check and putting everything back to normal. Any suggestions from You will be greatly appreciate it.
I also tried to disconnect the battery to see if that will reset anything. But it did not work..the lights comes up but I can't turn on the ac at all...I have also a tsx but I would like to avoid switching parts and stuff like that...
https://acurazine.com/forums/showthread.php?t=890420
Yes, that link is in the RDX section, and the TSB is for an MDX, but the same low quality A/C relay has been used for the past 10 years on all Honda/ Acura models, and the upgraded relay has been used on all Honda/ Acuras for the past several years.
WHile the link above, and the TSB, discuss a relay that has STUCK CLOSED, relays can also fail OPEN, meaning that the A/C clutch is never going to engage, so that the A/C compressor will never produce cold air.
Luis J. Rodriguez
09-12-2015 11:00 PM
