Climate control does not function until car warms up
Old Dec 31, 2013 | 11:00 AM
mastersonbilly's Avatar
4th Gear
I just bought an '06 TL with 99k miles. The climate control unit does not seem to want to come on until the car has been driven for 10-15 minutes. Occasionally I can shut it off and back on to get it working. Also the outside temp on the dash stays blank as well as the heated seats do not function. They all kick on at the same time. Any suggestions?
Old Dec 31, 2013 | 11:37 AM
03blackbeast's Avatar
That sounds like a fuse problem to me. Those are some pretty random things to be all broken at the same time otherwise.
Old Dec 31, 2013 | 11:45 AM
truonghthe's Avatar
If u talking about the heater then yes they do not blow air out unless the temp starting to get up, you can over ride this with fan speed instead. Heated seat element probably broken and it need to be fix.
Old Dec 31, 2013 | 12:19 PM
Bruce Banner's Avatar
Ditto to that, I'm guessing the OP lives in a snowy climate?
Old Dec 31, 2013 | 12:28 PM
GKinColo08TL's Avatar
[QUOTE=mastersonbilly;14810370]I just bought an '06 TL with 99k miles. The climate control unit does not seem to want to come on until the car has been driven for 10-15 minutes. Occasionally I can shut it off and back on to get it working. Also the outside temp on the dash stays blank as well as the heated seats do not function. They all kick on at the same time. Any suggestions?[/QUOTE
I disagree with the 2 guys above me...Truong and Bruce, the climate control system if set to "Auto" will not blow warm air until the motor has started to warm up. You can over ride the auto though by changing the mode button or manually pressing the fan switch. Also pressing the windshield defrost button on the right side of the panel will immediately activate the defrost function onto the windshield. Try those options, if it still isn't working then I think perhaps your system is stuck on the Auto setting.
Old Dec 31, 2013 | 12:43 PM
Will Y.'s Avatar
Registered but harmless
It's normal for the heat to kick in after the car has started to warm up when the climate control is in "auto" mode.
Are the temps below 0* where you live?
IDK if anyone else in sub-zero weather has the temp display issue, but there was a TSB for cars that showed "---" when the temps exceeded 100*F. The TSB can be found in the 3G Service Dept/Garage thread.
The seat heaters should start heating immediately, and mine can be felt within a few minutes when the temp is 40*+F if wearing denims + medium jacket (the driver's side has heating for the seat and back, but the passenger heater is seat-only). BTW, IDK if the seats are pressure sensitive and require weight on them to heat.
Welcome to AZ.
Old Dec 31, 2013 | 12:45 PM
+1 on the seats...they do take a few minutes to feel warm...
Old Dec 31, 2013 | 01:42 PM
4th Gear
It is in the mid 20's here in the AM. It's weird to me that everything kicks on at once. You can flip the heated seat switched and the lights do not illuminate. Temp stays at '---' and the climate control screen is blank and none of the buttons function...until the car decides it wants all of these temp related functions to work. Also, until this morning I've run the heat in manual mode rather than auto so I don't think it's stuck in auto mode.
Appreciate all the responses! Really hoping to get this resolved. It's not -zero but 20 degrees is still pretty brutal
Old Dec 31, 2013 | 01:49 PM
Alexns05's Avatar
Welcome to AZ.
Heated seats in 40+ degrees? You living in Africa?
Old Dec 31, 2013 | 06:15 PM
MarcoNorthPolo's Avatar
KCCO
Ha! No, it's not.... By the way, welcome to the site.
Old Jan 1, 2014 | 12:24 AM
Will Y.'s Avatar
OK, that doesn't sound right at all-- it sounds like a loose connection at a fusebox or at the MICU at best.
Any aftermarket work on the audio, navi system or installs of remote starters or alarms?
If so, check the aftermarket wiring and adjacent connections.
If not, I'd replace the climate control fuses in the interior and underhood boxes (one might be bad, but not totally blown), then check the voltage/amps running through the system.
Marina del Rey is two miles away and I've always lived near the coast in CA, so anything under 50*F is cold to me!
I use the heated seat whenever the interior temp is below 60*F, too...
Old Jan 1, 2014 | 04:18 AM
paperboy42190's Avatar
In SoCal 40 F is definitely considered cold.
Old Jan 1, 2014 | 01:17 PM
nfnsquared's Avatar
OP, both the climate control unit and the seat heater relay receive power via C506 which is a blue junction connector under the left side of the dash. Check that connector and see if it's loose.
They also both share ground G503 which is under the center console, right side above the ECM. It's possible that that ground is loose.
Also, the power mirror switch is powered through C506. If you notice that the switch will not move the mirrors at the same time that the seat heaters and climate control don't work, then it's likely associated with that connection.
The power wire coming into C506 (from fuse #30 in the under dash fuse box) is N20 (BLK/YEL). Check to be sure that wire is securely fixed within the C506 connector and/or put a voltmeter on the connector at that terminal and see if you have power (with key on II).
Old Jan 1, 2014 | 01:36 PM
nfnsquared's Avatar
Edit: Just read your post in the other older thread. Since your mirrors also don't work, then it has to be a loose connection on the power wire coming from fuse #30 or maybe fuse #30 (7.5A) is loose?
I'd start by replacing fuse #30 with a new one. Then if you still have issues, you'll need to check N20 at the C506 connector and see if you have power there.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
