A clicking noise when accelerating???
Old May 12, 2012 | 03:00 PM
  #41
usmarinedelta's Avatar
From searching, go to an autoparts store and buy a axle nut and replace yours. It's the cheapest way to go first. I did notice (more costly) when I replaced my axle and ball joint, the noise was gone, I assume it was the axle on the driver side.
Old May 31, 2012 | 12:34 AM
  #42
summerayu's Avatar
Originally Posted by joneill44
I think I have the same problem. Coming from the front on both left and right side
The first noise happens almost right away. Second comes around 6-8secs. Third time around 12sec. Last one is at the 18sec mark.
http://youtu.be/iZKiVxt5JHI
I am having the same clicking sound, were you able to get it fixed? I am planning to get a set of axle nugs and replace them.
Old Sep 14, 2012 | 08:36 PM
  #43
UNC_Tl's Avatar
Exact same issue
Hey everyone. i recently purchased a 2005 Tl 6 Spd. The clicking noise has started all of a sudden. I purchased the car like a week back and it was not there. Day before yesterday I slammed the breaks real hard and they kind of locked and the car skidded for a while. Ever since then, the noise is there. I am taking it to a mechanic tomorrow and am getting the axle nut tightened. From what I understand, the noise isn't coming due to brakes being worn out or something. If anyone has any suggestions it would be great.
I will let you know tomorrow what I hear about it.
Old Mar 29, 2014 | 09:35 PM
  #44
McCollins23's Avatar
Chapter Leader (Midwest Region)
Just noticed this issue with my drivers side this week. I am going to try to replace the axle nut first and if that doesnt fix it I will try the other fixes. Are you guys using only the OEM replacements or is something from Dorman (Advance Auto Parts) an acceptable replacement part?
Old Jul 1, 2014 | 10:39 AM
  #45
mattpete's Avatar
did you ever get your issue sorted out?
I have a different issue from the ones listed above
My click happens only when I let off the gas pedal after starting from a stop, and it only happens once. It does not happen upon braking only accelerating. If I continue to accelerate while moving it does not click, only from a start.
Any suggestions?
Old Jul 1, 2014 | 10:40 AM
  #46
mattpete's Avatar
I hope that made sense! ^^^
Old Jul 1, 2014 | 12:12 PM
  #47
CG's 3GTL's Avatar
Originally Posted by CG's 3GTL
Yea so that makes 2 of us... I hear that its a heat shield issue also but its been getting louder and its been going on since I purchased the car...
I forgot to update my info , so my issue here ended up being the Power steering pump, I had a cheap aftermarket PSP installed, once it was replaced the issue went away.
Not sure if you all have found out your cause or not...
Old Jul 1, 2014 | 04:49 PM
  #48
Fender Bender's Avatar
07 TL Type S
I'm having this same issue.
Just got an 07 TL-S 2 months ago.
Sounds like a CLANG noise. Like two pieces of metal hitting together. Only happens 1-3 times and goes away. Never on accelerating or braking- always on coasting around 2-5 MPH
Of course, I have it under extended warranty, and the dealership cannot figure out the issue. I even had to come back and drive through the parking lot with the technician to show him what the problem was.
Old Jul 8, 2014 | 05:56 PM
  #49
Silva95teg's Avatar
06 WDP/Ebony MT NAV ASPEC
I have to say my click came back. I replaced my axle nuts and it is still there but greatly reduced in volume. It almost sounds like there is a tiny bit of play where the axles are splined and it rotates there and clicks. My nut is torqued to spec unless my wrench is off. It only clicks right when i start to accelerate and then once when i am decelerating.
Old Dec 9, 2014 | 09:09 PM
  #50
EPPD2352's Avatar
2010 Acura ZDX Engine Noise
I am experiencing a rattling noise when accelerating slowly or quickly from the engine. I took it into the Acura dealership and they said they here it but the diagnostics check okay. A luxury vehicle should not be making these types of noises.
Any Ideas
John
Old Dec 10, 2014 | 01:25 AM
  #51
Will Y.'s Avatar
Registered but harmless
A heat shield, bad engine mounts or a bad pulley or bearing off the serpentine belt?
If it's one of those last two, the techs should have been able to diagnose it.
You might try the ZDX sub-forum, which is linked at the very top of the page, along with links to the other Acura models.
Welcome to AZ.
Old Aug 10, 2015 | 02:20 PM
  #52
07 TL Type S
I forgot to ever respond to this if anyone is having the same issue - it was a pebble inbetween the tire and the wheel, believe it or not.
The porter acutally figured it out after 2 mechanics checked it out and couldn't find anything. Get that kid a raise!
Old Feb 1, 2017 | 05:31 PM
  #53
cobra10363's Avatar
Does anyone have an update on this clicking noise when accelerating? I also have the same issue on my 10 RL.. I notice it ticks at very low speeds and slightly louder when i reverse.. I read to the entire thread and I don't think anyone has gottend to the bottom of it.. I honestly don't think a Axle nut is the culprit. An axle perhaps may have more reasoning..
Has anyone replaced the axles and know if that's the culprit or gotten to the bottom of it.
Old Feb 1, 2017 | 06:29 PM
  #54
kbouchard1092's Avatar
Yes, i have encountered this numerous times on the 3G TL.
The problem most the thread is describing is a more of a "Tink" noise then a clicking.
This is cause the grease that should be used on the face of the axle comes out (where it meets the wheel bearing) When axles are changed you should be using Honda MOLY PASTE M-77 08798-9010
If you are experiencing a "Tink" when accelerating, buy new axle nuts, remove old axle nut and axle (from the wheel side only) and then grease the disc that is pressed onto the end of the axle, re-torque.
I have fixed at least 5 TL/RL that had this issue.
In some cases, people replace the axle when in reality all that was needed was a little grease.
Mike734
Dec 10, 2021 01:25 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
copmagnet82
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
