Chronic pulling to the left
Old Oct 5, 2010 | 07:35 PM
daytona538's Avatar
8th Gear
Ever since I bought my car it has been pulling to the left. Acura says the shocks are ok, no alignment problems, toe and camber are ok also. Any suggestions as to why?
Old Oct 5, 2010 | 07:37 PM
daytona538's Avatar
8th Gear
Car
It is a 2005 TL 6 speed manual transmission
Old Oct 5, 2010 | 08:34 PM
nfnsquared's Avatar
Did they actually put your car on an alignment rack and take measurements? If so, they should have given you a print (a8d charged you $80 or so). Scan that and post it or post the numbers.
If they didn't put it on a rack, then they have no clue if your alignment is good or not...
Old Oct 6, 2010 | 02:54 AM
jwr0ng626's Avatar
how are your tires? old? uneven wear?
Old Oct 6, 2010 | 06:43 AM
johnny3's Avatar
Tires or alignment.
Old Oct 6, 2010 | 09:03 AM
VQPower37's Avatar
if everything is truly in spec, its probably a bad tire, swap left to right and see if that changes the direction of the pull
Old Nov 5, 2010 | 05:07 PM
daytona538's Avatar
8th Gear
left front
camber -0.3
toe .01
right front
camber -0.6
toe.01
front
total toe .01
steer ahead 0.0
left rear
camber -1.2
toe .1
right rear
camber -1.4
toe .07
rear
total toe .18
thrust angle .02
Old Nov 6, 2010 | 07:40 PM
acuragus's Avatar
General Tires?
I bought a 2006 with 36000 miles, factory certified. Car would pull and take a set on some lines. Replacing the General tires with Michelin's fixed it 95%. The Generals had deep tread and hard rubber.
Old Nov 6, 2010 | 09:27 PM
I hate cars's Avatar
Most likely the tires. As it was said, swap the front tires from side to side. If it starts pulling to the right, it's the tires. If no change, it's the suspension.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Skirmich
Oct 1, 2015 12:59 PM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
