check light codes question
Old Jun 18, 2012 | 09:54 PM
ep3kid914's Avatar
recently the checklight went on on my 04 tl auto
p00174- presenet. system too lean
p0848- 3rd pressure switch curc high
the second what i pressume is for the 3rd and 4th tranimssion switch so i replaced them (yes i did search and thats all i found so i just switched them)
now for the first one i have no clue how to get it off i did take it to the dealer to get the codes read up but they didnt tell me what i had to do to remove it and i searched and nothing came up
anyone know? thanks
Old Jun 19, 2012 | 12:22 PM
ep3kid914's Avatar
Anyone
Old Jun 19, 2012 | 02:05 PM
imakeholesinu's Avatar
From what I'm reading that is a generic OBD code, I would say it is either a bad Mass Air Flow sensor or perhaps a vaccum leak. It could be that your Mass Air Flow sensor is dirty, you have a bad hose somewhere or that your fuel filter is bad.
Old Jun 20, 2012 | 08:12 PM
Weavz's Avatar
I've been dealing with this same issue, Too Lean. Been told it's one of the hardest to diagnose. I got the mass airflow sensor ($56 from Delray) and the Accelerator Pedal Position sensor ($127.00), the later being for a separate code I got specifically from that. Here's the responses I'm getting -
"run injector cleaner through it, and put good gas in. Our cars drive like crap in the summer anyway."
I've had my O2 Sensor replaced, it went away for a few months, and now it's back. Will update after the MAF is installed.
Old Jun 20, 2012 | 08:59 PM
ep3kid914's Avatar
oh i see yea the acura dealer didnt even bother telling me how i can remove it but i guess ill be changing that maf sensor and see it from there
also just today my car was running good, turned the car off to pump gas when i turned it back on it acted wierd like laged when i started to drive like it was struggueling to drive so i turn it off and did the same and just drove not pass 15 mph since i was in a street but once i got to the highway drove normal anyone know what it can be and i have no warning lights showing on my dashboard and transmission oil is leveled fine
mada51589
Jan 9, 2025 04:40 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
Stu2414
Aug 30, 2015 07:30 PM
