Check engine P0767, P145C, P0497 :(
A quick google search of those codes shows that:
P0767 - Shift Solenoid Valve D Stuck On
P145C - Fuel Tank Pressure Sensor Range/Performance
P0497 - Evaporative Control System Low Purge Flow
Lots of good info out there already on this to at least start the search.
ACURA TL 2007 TRANSMISSION ISSUE 3rd TO 4TH GEAR
odd jerk from 3rd to 4th gear. doesnt always do it, but its starting to happen more.
also my check engine light has came on and the code reads
any info on a efficient way to fix would be appreciated !
Starting multiple threads to try and get a fast response is not the way to do things. You've already been told what each code means, now do Google searches and read how to fix them. Each one has been covered extensively.
Mods plz close thread
anoop
3G RDX (2019+)
45
Dec 11, 2018 02:54 PM
cocrh
Nov 29, 2018 09:29 AM
