Check Engine with the following codes
Hi Guys
My 2004 TL with 170k has CEL (for a few months) and pulled these codes
P0497 EVAP Canister Low Purge Flow
P0457 EVAP SYSTEM FUAL LEAK- Replace fuel cap
P2628 Rear A/F Sensor bank 1 sensor 1-- Circuit voltage too high
I have replaced the fuel cap today. Will reset the battery too. Is it safe to order the O2 sensor? No change as gas millage --still getting 23 MPG average.
Side issues: Just a little hard to start. I dont think it is related. If i put the key in, turn the key to on and wait for all the beeping to stop, then crank. it will start right away. If i try to start right away, it take a long crank to start
Thanks in advance. Did some search but don't want to buy anything i dont need. Got inspection coming up next month
Huy
Huy
Also beside OEM, is denso the best option? I know from searching not to use Bosch---- and is this the correct part?
https://www.amazon.com/Denso-234-5010-Fuel-Ratio-Sensor/dp/B00199DZT4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1486842870&vehicle=2004-58-749-------------0&sr=1-2&ymm=2004%3Aacura%3Atl&keywords=Denso+o2+sensor+for+2004+acura+tl
Bank1 Sensor 1
![https://www.amazon.com/Denso-234-5010-Fuel-Ratio-Sensor/dp/B00199DZT4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1486842870&vehicle=2004-58-749-------------0&sr=1-2&ymm=2004%3Aacura%3Atl&keywords=Denso+o2+sensor+for+2004+acura+tl](https://acurazine.com/forums/images/misc/amazon_icon.gif)
Bank1 Sensor 1
