Charging problem
Old 02-11-2016 | 07:23 PM
ShaunD's Avatar
3rd Gear
Charging problem
I have an 06 TL, have new battery, alternator, & starter. Battery light just started coming back on a day after new alternator was installed. I need help!!! What else could be going on???
Old 02-11-2016 | 07:24 PM
Check your grounds and battery terminals and cables
Old 02-11-2016 | 07:26 PM
ShaunD's Avatar
3rd Gear
They look good, clean & thight
Old 02-11-2016 | 07:37 PM
JJones91's Avatar
Could be a faulty alternator. It happens. Happened to me 3 times, before giving up and going to a different brand.
Old 02-11-2016 | 08:06 PM
Jesstzn's Avatar
Did you physically take them off and look or just visually ... Doesn't take much to mess up a ground.
Old 02-11-2016 | 09:24 PM
ShaunD's Avatar
3rd Gear
Did a visual, I'm gonna do a cleaning & see if that was the problem
Old 02-12-2016 | 12:14 AM
JRTL92's Avatar
6th Gear
That is the exact same problem I dealing with. Debating on getting an alternator. Sounds just like yours because all of my grounds look clean also.
When my battery is hook up, mines creates a fair amount of corrosion on the positive terminal regardless of how often I clean it. going to check mine grounds again, but I know for a fact it needs an alternator.
Old 02-12-2016 | 07:11 AM
I just replaced a battery (Thanks Aaa) for this exact issue and it seemed the positive post had a slight crack that seeped acid and corroded the terminal. ( it ate through completely) Charging problem-photo464.jpg
Ended up replacing terminal and same thing happened which led me to the post. Replaced battery and so far so good!
Old 02-12-2016 | 07:32 AM
Turbonut's Avatar
I just replaced a battery (Thanks Aaa) for this exact issue and it seemed the positive post had a slight crack that seeped acid and corroded the terminal. ( it ate through completely) Attachment 34617
How could it have gotten that bad? Looks like it hadn't been serviced for years.
OP-Get a multimeter, inexpensive and can be used for multiple tests, home/auto, and check battery voltage @ 12.4 volts with engine off. Start car and see if charging @ 14 volts with test leads on the bat terminals, then on the cable ends.
If alternator was a remanufactured unit from a store e.g. AutoZone, then probably junk.
Old 02-12-2016 | 08:00 AM
Like I said the plastic around the post had probably failed causing acid to leak out slowly and corrode it I replaced it with an aftermarket terminal and in two weeks, it happened again.
I swear I take care of her!!! I haven't even had the car for more than 2 years
Krisbo26
04-21-2020 01:37 PM
neuronbob
3G RLX Problems & Fixes
10-20-2019 03:55 AM
Evilocity
04-22-2016 10:33 AM
VNMISS04
02-03-2016 05:28 PM
TLMichelle
1G TL (1996-1998)
01-20-2016 12:56 PM
