Changing axel assembly
Old Jan 6, 2013 | 11:28 PM
ricknsxt's Avatar
hi all changed right front axel on auto base right side. automatic
had trouble getting spline all the way in by rotor, was i suppose to remove antilock sensor first? now i got abs light on, must have broke it.
thanks for any info. did finally get spline thru with a rubber mallet but it was tight.
Old Jan 7, 2013 | 05:27 AM
GrwnUpRcer's Avatar
No you don't have to remove the abs sensor. Should have used a little grease on the splines to get it through.
Old Jan 7, 2013 | 10:35 AM
SpiderX1016's Avatar
It's a good idea to remove the sensor cause they're pretty easy to break as you know now.
Aug 15, 2019 12:58 PM
Heyzuez20
Oct 14, 2015 07:18 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Aleax
Sep 11, 2015 11:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
