changing ATF fluid.
changing ATF fluid.
Is there a diy or could someone tell me where the drain bolt is and the fill bolt is on the 3g auto tls. I am needing to change mine but havnt had much luck searching this information. Any help is very much appreciated.
LIST/RAMEN/WING MAHSTA 짱
C-012 in the 3G TL Garage: https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
i just did mine yesterday, its not necassary to remove/move the fuse box. just get a long extension.
other than that, the DIY is awesome and makes it as easy as an oil change.
Here are the directions as well:
Oil Life reset 3G Garage #F-157: https://acurazine.com/forums/3g-tl-2004-2008-93/oil-life-reset-3g-garage-f-157-a-556666/
nanos
11-12-2015 08:41 PM
