Changed starter still doesn't work
Old Jul 6, 2013 | 08:55 AM
  #41
Ciroqboy's Avatar
Originally Posted by Nik83
The ignition wire to the starter has 12v checked every fuse in the car. Post's #35 and #36 I did that and nothing happened
That sucks. I'm currently having the same problem with mine. Except mine is manual, and starts sometimes. I understand the frustration
Old Jul 6, 2013 | 09:03 AM
  #42
Project_CLean's Avatar
MMkay.
Ciroq, it's probably your starter that's causing the intermittent start problem.
OP already did this and now he's got the same problem, which isn't very likely. So we are trying to figure out if he is missing something.
Old Jul 6, 2013 | 09:48 AM
  #43
Nik83's Avatar
I have a manual as well! And still trying to figure this thing out
Old Jul 6, 2013 | 10:08 AM
  #44
MMkay.
OP, what kind of starter did you buy? I can't help but think there's something that you're missing.
Old Jul 6, 2013 | 10:30 AM
  #45
Nik83's Avatar
Duralast import.
Old Jul 6, 2013 | 10:41 AM
  #46
MMkay.
If I were you, take the starter out. Go back to AZ and have it tested, or swapped for a new one.
I used to work at AutoZone, and had TONS and TONS of complaints and comebacks about their starters and alternators. Just about anything remotely mechanical manufactured by their company. I wouldn't be surprised if the starter you picked up is BAD to begin with...
Old Jul 6, 2013 | 11:29 AM
  #47
Nik83's Avatar
@ project clean you're right their starter was bad! I had them test the new they gave me and it was shit!!!! I just went online and ordered from oem acura parts. Com and hope this one will work with a little bit of extra cash!! Btw have you heard or oemacuraparts.com?
  #48
Ciroqboy's Avatar
My bad mine is AUTOMATIC. I been searching web and basically I got
1. Check battery
2. Starter
3. Neutral safety switch (probably not necessary with manual)
Old Jul 6, 2013 | 11:36 AM
  #49
Ciroqboy's Avatar
Ok. So don't buy duralast..... Got it.
Old Jul 6, 2013 | 11:39 AM
  #50
Nik83's Avatar
@ciroc have you tried troubleshooting. Take a tester and see if your starter has power should have 12v I think but if you read some of the posts that these awesome guys wrote that'll might help you out!
Old Jul 6, 2013 | 11:52 AM
  #51
MMkay.
Ciroq, it doesn't matter whether you're AUTO or MANUAL.
Starters tend to go bad on the 3G's period.
Old Jul 6, 2013 | 12:34 PM
  #52
pohljm's Avatar
OP, your car was not starting push starting it.............that eliminates the starter from the equation. Thats great that you identified your new starter as faulty, but if it wasnt starting push starting there are issues other than the starter or you didnt have the ignition on.
Old Jul 6, 2013 | 01:50 PM
  #53
I hate cars's Avatar
I've got a hunch he didn't know how to push start the car properly. If the new-new starter fixes the problem we will know for sure.
Old Jul 6, 2013 | 01:58 PM
  #54
MMkay.
^This. Especially since there was no other problems mentioned before the install, I doubt it has to do with anything other than the starter.
On the bright side, I just had a 3G UA7 come into the dealer saying that since the dealer performed an oil change, the car has problems starting intermittently. BOOM! warranty coverage for diag and brand new starter.
it was one of you guys I know it.
Old Jul 6, 2013 | 04:36 PM
  #55
Nik83's Avatar
They told me that the starter was weak and didn't have enough juice to spin the flywheel, it would kick but slow, when they tested it but it is kind of weird if starter was problem and pop start didn't run. Shit! Don't tell me another thing is fu@$ed!! Lets see what happens when this new starter comes on wednesday
Old Jul 6, 2013 | 04:41 PM
  #56
So was the key in the run position when you push started it?
Old Jul 6, 2013 | 04:56 PM
  #57
Nik83's Avatar
Yes it was!
Old Jul 6, 2013 | 05:05 PM
  #58
pohljm's Avatar
well then you got bigger problems than the starter. bump starting it took the place of the starter and spun the engine just fine. If it didnt fire then it will not fire with a new starter. I have driven cars for weeks without a starter just using hills.
Old Jul 6, 2013 | 05:48 PM
  #59
Nik83's Avatar
Lol screw this I'm walking!
Old Jul 8, 2013 | 06:17 AM
  #60
MMkay.
This is kinda pissing me off and it's not even my car.
Did you end up replacing the starter? Any news?
Old Jul 8, 2013 | 02:42 PM
  #61
Nik83's Avatar
The starter is coming in on Wednesday so I will not have any news till Wednesday night when I get the starter installed. I will keep you guys updated but something is weird and I don't know what it is. It's kinda hard to explain if I'm not a truly mechanic but I could definitely use some help if I can explain things clearer
Old Jul 8, 2013 | 02:49 PM
  #62
Ciroqboy's Avatar
I know the frustration. Makes you wanna get rid of the car. Good luck.
Old Jul 8, 2013 | 03:04 PM
  #63
because of a $100 starter?
Old Jul 8, 2013 | 03:44 PM
  #64
Ciroqboy's Avatar
The frustration of not starting. Of course I wouldn't get rid of it, might that's my first reaction out of anger lol
Old Jul 8, 2013 | 05:50 PM
  #65
boy, are you in for a lot of frustration!
I cant tell you how many times something has gone wrong with my installs.
I'm always adjusting and readjusting my mods so that they are PERFECT!
its never ending.
Old Jul 9, 2013 | 08:47 AM
  #66
MMkay.
its never ending.
Definitely. Plus every car has its quirks. The 3G is just a little extra fussy, lol. So both of you guys (ciroq & Nik) are in for some more exciting stuff.
Old Jul 9, 2013 | 10:41 AM
  #67
Comptechtl2367's Avatar
In for an update on this tomorrow... Why didnt you just get another aftermarket or reman starter from somewhere?
Old Jul 9, 2013 | 11:26 AM
  #68
Nik83's Avatar
All the places I went to had a lead time of 7-10 days and oem acura parts had it for 3 days so I went with them! I'm hoping for the best tomorrow guys!
Old Jul 9, 2013 | 09:31 PM
  #69
Pontz's Avatar
First time on forum :/
2005 acura tl my brake lights went out ..at the same time I was unable to shift it into gear (auto,used my key to put it in neutral to start my car).. Help?!
Old Jul 10, 2013 | 04:34 AM
  #70
3rdGenHybrid's Avatar
Pontz is a thread jacker lol.... If your horn doesn't work, you blew the fuse for the brake/horn (same circuit) if your horn works you need a new brake switch.
Op does your engine turn over freely? Sounds to me like something's locked up.
Old Jul 10, 2013 | 06:23 AM
  #71
MMkay.
He said he had no response at all to begin with,tried jumping it and so on but nothing. Then, he changed the starter and only had a "CLICK" . But it was an aftermarket starter from Autozone, which was later tested and failed. So he ordered a new one from Acura. We are all waiting to see if he fixes it .
OP, if the new starter doesn't work,take a video and post it. We want to see and hear what happens.
Old Jul 10, 2013 | 09:45 AM
  #72
Pontz's Avatar
Thumbs up
3rdGen: lol, wasn't trying to cut in. 1st time on forum (limited acces). Thx for the info I'll check it out.
Old Jul 10, 2013 | 01:37 PM
  #73
Nik83's Avatar
Will do!
Old Jul 10, 2013 | 02:25 PM
  #74
I would be working on my push starting skills while waiting on the starter. At least you would have a good idea that the starter is the main problem if you can get it started this way.
Old Jul 10, 2013 | 02:50 PM
  #75
Ciroqboy's Avatar
Looking forward to outcome as well. & thanks for all info. New battery & starter to be safe & no problems so far
Old Jul 10, 2013 | 06:28 PM
  #76
Nik83's Avatar
My baby is up and running!!!!!! And it was the starter, popped that thing right in and turned the key over and boom, started right up! Thank you all for helping me figure this out! You guys are great and hopefully there will not be any more major problems. If there is, I hope you guys are still around! Again thanks.. Nik.
Old Jul 10, 2013 | 06:50 PM
  #77
Nik83's Avatar
So dealer/ mechanic said it was the starter, but he sold me the starter??? Am I missing something? But anyway, it is running.
Old Jul 10, 2013 | 07:01 PM
  #78
cherplex's Avatar
^^^Glad to hear. I'm having similar issue. Will make sure shop uses oem part.
Old Jul 10, 2013 | 07:14 PM
  #79
Nik83's Avatar
I asked this guy who helped pop start the car, the fool only put the key on the accesory setting(II). What an idiot!!! All his time I was losing my freaking mind!!!
Old Jul 10, 2013 | 07:50 PM
  #80
The key should be in II to pop start it. Either first or 2nd gear. Push until the car gets some momentum and pop the clutch. Apparently you were doing it wrong if it didn't work. Or your 6 speed manual is an automatic.
