Changed starter still doesn't work
#41
#46
MMkay.
If I were you, take the starter out. Go back to AZ and have it tested, or swapped for a new one.
I used to work at AutoZone, and had TONS and TONS of complaints and comebacks about their starters and alternators. Just about anything remotely mechanical manufactured by their company. I wouldn't be surprised if the starter you picked up is BAD to begin with...
Nik83 (07-06-2013)
#47
@ project clean you're right their starter was bad! I had them test the new they gave me and it was shit!!!! I just went online and ordered from oem acura parts. Com and hope this one will work with a little bit of extra cash!! Btw have you heard or oemacuraparts.com?
#48
#50
@ciroc have you tried troubleshooting. Take a tester and see if your starter has power should have 12v I think but if you read some of the posts that these awesome guys wrote that'll might help you out!
#52
OP, your car was not starting push starting it.............that eliminates the starter from the equation. Thats great that you identified your new starter as faulty, but if it wasnt starting push starting there are issues other than the starter or you didnt have the ignition on.
#53
#54
MMkay.
^This. Especially since there was no other problems mentioned before the install, I doubt it has to do with anything other than the starter.
On the bright side, I just had a 3G UA7 come into the dealer saying that since the dealer performed an oil change, the car has problems starting intermittently. BOOM! warranty coverage for diag and brand new starter.
it was one of you guys I know it.
#55
They told me that the starter was weak and didn't have enough juice to spin the flywheel, it would kick but slow, when they tested it but it is kind of weird if starter was problem and pop start didn't run. Shit! Don't tell me another thing is fu@$ed!! Lets see what happens when this new starter comes on wednesday
#56
So was the key in the run position when you push started it?
Nik83 (07-06-2013)
#58
well then you got bigger problems than the starter. bump starting it took the place of the starter and spun the engine just fine. If it didnt fire then it will not fire with a new starter. I have driven cars for weeks without a starter just using hills.
thoiboi (01-09-2015)
#61
The starter is coming in on Wednesday so I will not have any news till Wednesday night when I get the starter installed. I will keep you guys updated but something is weird and I don't know what it is. It's kinda hard to explain if I'm not a truly mechanic but I could definitely use some help if I can explain things clearer
#68
All the places I went to had a lead time of 7-10 days and oem acura parts had it for 3 days so I went with them! I'm hoping for the best tomorrow guys!
#70
Pontz is a thread jacker lol.... If your horn doesn't work, you blew the fuse for the brake/horn (same circuit) if your horn works you need a new brake switch.
Op does your engine turn over freely? Sounds to me like something's locked up.
Pontz (07-10-2013)
#71
MMkay.
OP, if the new starter doesn't work,take a video and post it. We want to see and hear what happens.
Ciroqboy (07-10-2013)
#72
3rdGen: lol, wasn't trying to cut in. 1st time on forum (limited acces). Thx for the info I'll check it out.
#74
I would be working on my push starting skills while waiting on the starter. At least you would have a good idea that the starter is the main problem if you can get it started this way.
#76
My baby is up and running!!!!!! And it was the starter, popped that thing right in and turned the key over and boom, started right up! Thank you all for helping me figure this out! You guys are great and hopefully there will not be any more major problems. If there is, I hope you guys are still around! Again thanks.. Nik.
#79
I asked this guy who helped pop start the car, the fool only put the key on the accesory setting(II). What an idiot!!! All his time I was losing my freaking mind!!!
#80
The key should be in II to pop start it. Either first or 2nd gear. Push until the car gets some momentum and pop the clutch. Apparently you were doing it wrong if it didn't work. Or your 6 speed manual is an automatic.
