Changed Mapsensor Now Code Saying ECU Bad
Old Jul 4, 2016 | 09:14 AM
ProtoEX's Avatar
5th Gear
I changed the map sensor on my 04 TL and now its throwing code P2227 Barometric Pressure Sensor. So im thinking maybe the map sensor is not good i dont know has anyone had this problem before
Old Jul 4, 2016 | 10:43 AM
Why did you change the MAP sensors in the first place ?
Old Jul 4, 2016 | 01:43 PM
ProtoEX's Avatar
5th Gear
Code for the map sensor came up so i changed the map sensor now the ecu code is showing so im trying to figure out should i just buy a acura map sensor or buy a ecu
Old Jul 4, 2016 | 01:49 PM
You need to give us tons more information...you're just throwing parts at the problem. We don't know what car you have year, mileage, problems, now it sounds like you didn't even buy an OEM MAP sensor...
It's damn confusing trying to troubleshoot when you give us tidbits of misinformation
Old Jul 4, 2016 | 03:49 PM
ProtoEX's Avatar
5th Gear
2004 Acura TL 177386 Miles auto, just changed the air filter when changing the map sensor now the car keeps showing code p2227 and wont change gears unless it reaches about 5krpm. I can make it change gears by pressing the accelerator and easing off it then pressing it again. Also its makes a strange noise when its time to change gears
E39
Feb 9, 2016 01:12 PM
