Center console clicking
Old 09-08-2008 | 01:54 PM
bd153's Avatar
8th Gear
On my center console where the shift knob sits, I'm getting a clicking/chattering because it seems like the panel is loose or something. Does anyone have a fix or diagram to take this apart? It is there both on bumpy roads and even smooth pavement.
Old 09-08-2008 | 04:55 PM
240sx acura tech's Avatar
acura master tech
just open the bottom cubby hole and pull up on the lower shift cover. the top and bottom come off togather. get some foam and cut it in thin strips and place it on the under side of both. place it on the ridges of the under side of the bigger cover then place them back togather.
Old 09-08-2008 | 05:03 PM
sixsixfour's Avatar
any diagram or DIY pics on how to do this?
Old 09-08-2008 | 07:44 PM
acura master tech
i will post tuesday pics
Old 09-09-2008 | 11:35 PM
acura master tech
here is how to fix the clicking
fisrt you will need honda foam. runs about $45 a box. well spent if you own a 01- 08 tl
first remove the shifter and lock out cover
now filp them over and you will see ridges
now cut the foam into small but long with a razor
wrap it close to the middle edge on the lock out cover
now samething will the shifter cover
now just reinstall. it will be tight. make sure no foam is sticking out . test drive to confirm fix
mlody
12-04-2019 02:11 PM
vpasla1
09-17-2016 07:24 PM
InFaMouSLink
10-27-2015 06:52 PM
hashbrown
09-29-2015 12:13 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Center console clicking
